2DOF arduino mini project. Why am i getting no game inputs in the tuning center?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Dannick Eljon, Feb 11, 2023.
  1. Dannick Eljon
    Dannick Eljon New Member
    57Coins
    Hi there,
    This is my first post here but hopefully not my last. I am trying to make a small 2 DOF motion sim with an arduino to start with. I have used quite a few pages already but i'm still not getting any game data in the tuning center. I'm using the free version of simtools with LFS.
    Here are the links I used:
    arduino code:https://www.xsimulator.net/community/marketplace/rc-model-code-for-arduino-uno-2dof-expandable.89/
    connection diagram:https://www.xsimulator.net/community/threads/rc-model-for-motion-simulation.4600/
    Interface setup: https://www.xsimulator.net/community/attachments/rcsettings-jpg.48565/
    Axis assignments:
    I'm really new to this so I would love to hear it if somebody knows what i'm doing wrong. thanks in advance.
    153,950Coins
    +11,159 / 57 / -2
  3. Dannick Eljon
    57Coins
    thanks for that, how do i patch it for motion?
  4. Dannick Eljon
    57Coins
    153,950Coins
    +11,159 / 57 / -2
  6. Dannick Eljon
    57Coins
    Thank you so much! It works now, but the movements are a little bit to small. DO you have any idea how I can increase the output to my servo's?
    153,950Coins
    +11,159 / 57 / -2
  8. Dannick Eljon
    57Coins
    153,950Coins
    +11,159 / 57 / -2
    Do the servos move their full range in SimTools Output Testing, using a configured Default profile?
    With the Tuning Center the bigger the value the larger and smoother the movement, the smaller the value the sharper the motion response, but over a smaller range.
  10. Dannick Eljon
    57Coins
    Hi, I just tested. I do get the full movement. The problem is that if I change the maximum input. That doesn't change the amount of input i get from the game.
    153,950Coins
    +11,159 / 57 / -2
    What do you mean by "change the maximum input."? Which setting are you referring to?
  12. Dannick Eljon
    57Coins
    Hi, I mean the values in the red part of the tuning center. Can I send you a PM?
  13. noorbeast
    153,950Coins
    +11,159 / 57 / -2
    See the SimTools manual p.77, the Tuning Center lets you 'tune' the game data motion by setting the Max/Min values. A small value will mean it is reached quickly, giving snappy motion, in some cases a large value may not even be reached if the game data is not that high.
    The actual range use and how it is divvied up is via the Axis Assignment.
    PMs are not meant for problem solving, please see the Forum Rules: https://www.xsimulator.net/community/threads/forum-rules.9527/
