SimTools v3 Public Beta
  1. flipflop
    flipflop Member Gold Contributor
    Swansea
    382Coins
    3DOF, Arduino
    Thanks for that.
    With dirt rally 2, since there is no udp relay available on the plugin page as there was with f122, is there any way of utilising the same method?
  2. yobuddy
    51,527Coins
    I'll add it in the next couple of days buddy.
  3. yobuddy
    51,527Coins
    Update Posted :thumbs
    Fixed - HotKey (Used to Stop SimTools from a running game)
    Changed - Virtual window not closed after a game now.
    (Code cleanup and other fun stuff..)
    Dirt Rally 2 game plugin updated too!
    - better rate outputs
    - fixed udp relay
    - flipped roll and surge output for uniform output from game plugins.
  4. Krzysztof Dej
    Krzysztof Dej Active Member
    Poland
    1,100Coins
    And?? Write to like to the child :) so this r a new beter axis sygnal for roll pitch... So I need to change those axies to 4-6?
  5. yobuddy
    51,527Coins
    Roll output is the degrees you sitting at.
    It's a static output, the car is sitting at 30deg.
    Roll Rate, is how many degrees a second the input is changing.
    So the output is the amount of change from one input to the next.
    (normalized over 1 second)
    So if you come to a complete stop, the rate outputs will always be zero.
    You can think of it as changing the roll output into an acceleration rather than a static degree.
    I suggest you set axis 1a to roll and axis2a to roll rate and take a look at what happen in the virtual output sliders plugins when it runs.
    Take care!
  6. lVlemphiz
    lVlemphiz Member Gold Contributor
    Automotive Engineer
    252Coins
    3DOF, AC motor, SCN6
    So the super small window bug will only be fixed in the final update? I play on a 4k screen and I have to get up out my seat to read the menu when using it.
  7. yobuddy
    51,527Coins
    It's technically not a bug, it's just not finished yet.
    I do make corrections as I work on plugins, but I'm not worried about it until I get to finishing the skinning.
    Take care,
  8. lVlemphiz
    Automotive Engineer
    252Coins
    Gotcha so something to expect when it leaves Beta and not until.
  9. yobuddy
    51,527Coins
    When I get back to finishing the skinning.
    It's probably one of the non game plugins you are using, as the app itself is already setup right I believe.
  10. yobuddy
    51,527Coins
    Now available for SimTools v3...
    Linear Axis and Virtual Stewart Plugins :thumbs
    1) Generic 3D Linear Axis Plugin (Stewart platform support)
    Sim Setup
    2) Generic 3D Linear Virtual Plugin
    Please let me know how it goes...
  11. yobuddy
    51,527Coins
    So yea - we need Rotating version also...
    Rotating Axis and Virtual Stewart Plugins :thumbs
    1) Generic 3D Rotating Axis Plugin (Stewart platform support)
    Sim Setup
    2) Generic 3D Rotating Virtual Plugin
  12. Krzysztof Dej
    Poland
    1,100Coins
    Little suggestion. Maybe a reconnect button. When u start simtools and wifi not connected U must turn off sim tools. Maybe a little button "reconnect" if possible thanks for your work
  13. yobuddy
    51,527Coins
    It's designed to work with or without internet.
    Internet is only required for registration.
    So I'm not sure why you would need to "reconnect" is all, SimTools is not connected to anything when running?
  14. Krzysztof Dej
    Poland
    1,100Coins
    With no internet i don't see game plugins :)
  15. yobuddy
    51,527Coins
    Do you mean in the repo manager?
    If so, then yes your offline.
    But you can download them from here:
    https://simtools.us/plugin_library/
    And then just drag drop them into the main window to install.
    Take care,
  16. Moppi07
    Moppi07 New Member
    - 4Coins
    2DOF, JRK
    Can some one tell me what upd port AMS2 use ? Where ist the setting file location? I trie to setup simtools and simhub.
  17. Krzysztof Dej
    Poland
    1,100Coins
    Becouse of my nigh shifts and lack of English words I record video and also see it's call a demo mode. Here is video :
    Thank for your work
  18. itsumairu
    itsumairu Active Member
    Psychologist
    Indonesia
    440Coins
    yes, I just realize that we can't play the V3 on offline mode. because the license activation only work online.
    so V3 need a network connection.
  19. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Hi you dont need any UDP ports to make AMS2 work with Simtools and Simhub just set up the in game telemetry and both will work
  20. yobuddy
    51,527Coins
    This is just a bug, I will get it fixed.
