2dof rig. (Hopefully very cheap)
Discussion in 'DIY Motion Simulator Projects' started by Mattlekim, Jan 30, 2023.
  1. Mattlekim
    Mattlekim Member
    - 5Coins
    Built my own heavy duty u joint.
  2. zapata_h
    zapata_h Active Member
    España
    308Coins
    3DOF, AC motor, Arduino
    It is a good idea for those who do not have a universal joint
  3. Mattlekim
    Mattlekim Member
    - 5Coins
  4. itsumairu
    itsumairu Active Member
    Psychologist
    Indonesia
    440Coins
    curious how durable it is in action. good job!
  5. Mattlekim
    Mattlekim Member
    - 5Coins
    From the feel of it I think it will be very. Hopefully anyway
    153,770Coins
    +11,149 / 57 / -2
    Nice progress :thumbs
    Wen is the final assembly and initial testing?
  7. Mattlekim
    Mattlekim Member
    - 5Coins
    Iv just shorted my motor arms. With the rig been wood it's very heavy for the windscreen motors. Going to test tonight.
  8. Mattlekim
    Mattlekim Member
    - 5Coins
    Had to put battery on rear as counterbalance, due to oversight on my part. Version 2 out of aluminium will be much more compact.
    Just need to connect everything up and test now.
  9. Mattlekim
    Mattlekim Member
    - 5Coins
    Was hoping to have this working by now. Had an issue with motor 2. Only working in 1 direction. After much testing and resorting to applying 5v to the enable pin and power pin figure out I have a faulty h-bridge. Waiting for replacement
  10. Mattlekim
    Mattlekim Member
    - 5Coins
    Since waiting for my replacement h-bridge I decided to rebuild my rig as it's way way to heave and huge.
    Will have an better update soon
  11. Mattlekim
    Mattlekim Member
    - 5Coins
    Built a complete new rig out of wood..basic design that I'm going to use in aluminium in the future.
  12. Mattlekim
    Mattlekim Member
    - 5Coins
    Actually got it working :) got my self a cv joint for £6 to see if it would remove some of the unwanted rotation. but no difference. Limits of a wooden rig.
    Going to neaten up cables and submit a video.
