Question what is the minimum torque required for 4 dof
Discussion in 'Ready, set, go - Start your engines' started by Arta Yasa, Feb 14, 2023.
  1. Arta Yasa
    Arta Yasa Member
    878Coins
    Hiii
    I have 2 motor elektrik wheel chair with 300rpm and for now i will reduce to 60until 80rpm i check the torque become 28 until 30NM.
    And also i have 2 dcservo with wormgear reducer 1:50 170watt 32V 52rpm. I check the torque is 30 until 31NM.
    I have rig with me wheight around 100kg until 110kg.
    I ask for that motor inaf for make 4dof?? Because i see 4 dof without Ujoint like a 2dof. Before i spen many time and money for this.
    Thank you friend.
    My rig like this.
  2. zapata_h
    zapata_h Active Member
    España
    308Coins
    3DOF, AC motor, Arduino
  3. Mattlekim
    Mattlekim Member
    - 5Coins
    I know from test that having 4 motors one in each end will require more powerful motors than using a u joint. And 2 motors.
    When using a u joint the rig is fairly ballenced around the ujoint meaning the weight is been supported by it. Most of the motor power goings in to inertia, ie moving the rig, when using 4 motors you have the entire weight of the rig plus the person in it. The rear 2 motors will be taking about 60 to 70% of the weight.
    As has been mentioned previously you can use the above tool to work this stuff out
  4. Arta Yasa
    Arta Yasa Member
    878Coins
    So that mean 30NM not inaf for 4dof sir???
  5. Arta Yasa
    Arta Yasa Member
    878Coins
  6. Mattlekim
    Mattlekim Member
    - 5Coins
    Depends on your arm length , with a short arm probably. 30nm is strong, someone else may have done something similar to what you are.
  7. zapata_h
    España
    308Coins
    You must do the calculations to know how much weight a motor can move, for example, with a 10cm lever, the result will be in kilograms meter, from there make the distribution
