Unhandled exception has occured in your application.
Discussion in 'New users start here - FAQ' started by vrmall2405, Feb 20, 2023.
  1. vrmall2405
    vrmall2405 New Member
    - 53Coins
    Hello. Help me please. I am newbie. Installed the plugin from this page
    https://simtools.us/plugin/?varname=220&color=0e97dd
    and now all my settings for other games are gone. what should I do? Thank you!
    Unhandled exception has occured in your application. if you click Continue. the application will ignore this error and attempt to contine. if you click Quit. the application will close immediately.
    Code:
    System.NullReferenceException: Object reference not set to an instance of an object.
       at SimTools_GameManager.frm_GameManager.‫‭‮‍‬‪‌‌‬‌‌‮‭‏‏‫‫‏‍‏‫‬‮‮‮(IPlugin_Game )
       at SimTools_GameManager.frm_GameManager.LoadGameList()
       at SimTools_GameManager.frm_GameManager.frmMain_Load(Object sender, EventArgs e)
       at System.EventHandler.Invoke(Object sender, EventArgs e)
       at System.Windows.Forms.Form.OnLoad(EventArgs e)
       at System.Windows.Forms.Form.OnCreateControl()
       at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
       at System.Windows.Forms.Control.CreateControl()
       at System.Windows.Forms.Control.WmShowWindow(Message& m)
       at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
       at System.Windows.Forms.Form.WmShowWindow(Message& m)
       at System.Windows.Forms.Form.WndProc(Message& m)
       at SimTools_GameManager.frm_GameManager.WndProc(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    mscorlib
        Assembly Version: 4.0.0.0
        Win32 Version: 4.8.4614.0 built by: NET48REL1LAST_B
        Assembly Version: 0.2.6.0
        Win32 Version: 0.2.6.0
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/SimTools_GameManager.exe
    UneaZPaLWHjtjGfIyYsbFPWNzDcv
        Assembly Version: 0.0.0.0
    Microsoft.VisualBasic
        Assembly Version: 10.0.0.0
        Win32 Version: 14.8.4084.0 built by: NET48REL1
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
        Win32 Version: 4.8.4550.0 built by: NET48REL1LAST_C
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
        Win32 Version: 4.8.4605.0 built by: NET48REL1LAST_C
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
        Win32 Version: 4.8.4390.0 built by: NET48REL1LAST_C
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
        Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Core
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    System.Xml
        Win32 Version: 4.8.4084.0 built by: NET48REL1
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Runtime.Remoting
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    Game_PluginAPI
        Assembly Version: 1.0.0.0
        Win32 Version: 1.0.0.0
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/Game_PluginAPI.DLL
    System.Management
        Win32 Version: 4.8.4435.0 built by: NET48REL1LAST_C
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
    EpicRollerCoasters_GamePlugin
        Assembly Version: 3.0.0.0
        Win32 Version: 3.0.0.0
        CodeBase: file:///C:/Users/GameV/AppData/Local/SimTools/GamePlugins/220_GamePlugin.dll
    enabled.
    For example:
    <configuration>
    </configuration>
      168.6 KB
      260
  2. vrmall2405
    - 53Coins
    Проблема решена, путь удаления
    C:\Users\GameV\AppData\Local\SimTools\GamePlugins
    in the folders all the data is located with
    Epic rollercoaster
    153,764Coins
    +11,149 / 57 / -2
    SimTools v3 plugins are not compatible with SimTools v2.
    SimTools v2 plugins are here: https://www.xsimulator.net/community/marketplace/
