Question why pitch not working in game???
Discussion in 'Ready, set, go - Start your engines' started by Arta Yasa, Feb 20, 2023.
Tags:
  1. Arta Yasa
    Arta Yasa Member
    824Coins
    why pitch not working?? but when output testing everything works normally. and when in the game and pressing the accelerator pedal, DOF does not provide a rear pulling force (pitch goes up) as well as when braking the pitch does not give a trip down. only he is in the midpoint. but for roll I think work. and is there any reference for this? for example the output testing roll when we slide it to negative it should rig rig to the right or left, and vice versa, because I was right "but confused by this. thank you very much
    151,985Coins
    +11,061 / 56 / -2
  3. Arta Yasa
    Arta Yasa Member
    824Coins
    This is my setup, when i output testing everything is ok, roll, pitch, heavy, sway, surge are ok.
    I follow the intruction on DOF roll tilt left or right, same also for other axis
    151,985Coins
    +11,061 / 56 / -2
    What are the game Tuning Center values when the game is running, particularly for surge?
    Have you captured the Tuning Center values, see the tuning tips in the FAQS: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  5. Arta Yasa
    Arta Yasa Member
    824Coins
  6. Arta Yasa
    Arta Yasa Member
    824Coins
  7. Arta Yasa
    Arta Yasa Member
    824Coins
    When create motion profile we drive the car fast or slow sir? Also for the brake and accelerator? When we go fast an brake with maximum? Or better slow run the car and slow also for the brake?
    151,985Coins
    +11,061 / 56 / -2
    The Tuning Center values are likely too high, in particular for surge, which for some games may end up being a value below 1.
    Temporarily disable other axis by setting their values to 0 and as a starting point set surge to 0.5 in the Tuning Center. You should be able to feel the effect and tune it further from there, before re-enabling other axis.
    When trying to capture Tuning Center Max/Min values, aim for about 80% of your normal race speed, you don't want to crash or hit anything, but you do want to realistically capture the motion at speed and track events, such as potentially riding a curb in a corner.
  9. Arta Yasa
    Arta Yasa Member
    824Coins
    Ok i got it sir, but for now, when never i hit or crash something arduino will disconnect sir, what wrong? Because of emi??
    151,985Coins
    +11,061 / 56 / -2
    EMI can be one possible cause/factor, but there are others, the settings (SMC and SimTools) may lead to power spikes that the PSU and/or USB (normally produces and audio alert) can't handle.
    As an experiment, in Game Manager, under Profile Editor, lower the Intensity Lever to say 94%, does the disconnect still happen?
  11. Arta Yasa
    Arta Yasa Member
    824Coins
    Ok i will try, and how about add breaking resistor for each psu sir??
    151,985Coins
    +11,061 / 56 / -2
    The simplest approach is to use a battery to power the rig and absorb power spikes, with the PSU keeping the battery charge topped up.
  13. Arta Yasa
    Arta Yasa Member
    824Coins
    When i decresis the intensity to 90 not disconnect again, but i want to ask what happen when the inyensity not 100%?
    151,985Coins
    +11,061 / 56 / -2
    Decreasing Intensity adds global smoothing. Likely 90% is way too much, you may get away with something like 97%, it takes a bit of experimentation.
  15. Arta Yasa
    Arta Yasa Member
    824Coins
    Alright sir, and for captur motion profil max and min it supostobe finis from the start until finos? Like on AC i used track monza, but for me beginer when i speedup the car it will crash. Si can i just run half or qarter track??
  16. noorbeast
    151,985Coins
    +11,061 / 56 / -2
    A shorter run should give you a base to work from, you can manually tweak it after that.
  17. Arta Yasa
    Arta Yasa Member
    824Coins
    Ok sir, and for LFS and AC is defrent profil setup sir?? Because i set on LFS are don and surge going true. But when i run AC the surge going wrong sir, whe i press brake going up, when i press acceleror going down sir
  18. noorbeast
    151,985Coins
    +11,061 / 56 / -2
    Each game should have a motion profile tuned specifically for it.
