Question SMC3 and Simtools not working after replace my CPU and Motherboard
Discussion in 'SimTools DIY Version' started by itsumairu, Feb 21, 2023.
  1. itsumairu
    itsumairu Active Member
    Psychologist
    Indonesia
    440Coins
    as the title say, my motion rig not working after I replace / upgrade my CPU and motherboard.
    when I turn on power, it keeps on and off every 10 seconds.
    and my arduino not consistent detected on SMC3, sometimes works and doesn't.
    for the simtools, the output testing doesn't works.
    anyone know how to fix this?
    Thanks in advance
    --- edited ---
    notes:
    I connect the arduino direct to my motherboard usb3.0 or usb2.0 is got the same problem.
    I have double check the port on smc3 and simtools, its the correct port.
    I've uninstall and reinstall the program, but still the same.
  2. itsumairu
    Psychologist
    Indonesia
    440Coins
  3. yobuddy
    51,534Coins
    I can't really tell in the video as it's so small, but is SMC3 and SimTools running at the same time?
    As they will conflict with each other is all.
  4. itsumairu
    Psychologist
    Indonesia
    440Coins
    no, I run One at a time.
    here another video to show you how the problems occurs
  5. itsumairu
    Psychologist
    Indonesia
    440Coins
    finally, found the culprit!
    its the simhub. :(
    you have to make an exception for the port.
    glad I don't take the hard way, reinstall my windows. :grin
