radist07's rig
Discussion in 'DIY Motion Simulator Projects' started by radist07, Mar 11, 2023.
  1. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    Good day! made the settings according to your video tutorial. when I go to the Output Testbng tab and move the axes to +2, the motors turn sharply a quarter of a turn and that's it! No matter how much I pull the slider, there is no further movement. when I pull the slider to -, the motors do not move at all, they just twitch. Please tell me how to fix this
  2. Rull
    Rull New Member
    - 66Coins
    2DOF, 3DOF, Arduino
    Hello good morning.
    I would like to help you but the Spanish translation is not good and I don't understand the question, I don't really know what you mean.
    154,508Coins
    +11,184 / 57 / -2
  4. Rull
    Rull New Member
    - 66Coins
    2DOF, 3DOF, Arduino
    Hello again, this gentleman has many videos where he explains very well. step by step.
    I hope he can help you.
    D Max
    I hope I've helped.
  5. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    I am Russian and the translator also does not allow me to say it correctly. I'll make a video and you'll understand
  6. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    Hello! I have a problem and I can't solve it, in smc3Utilis the motor works fine, and in SimTools only in + and then with a sharp movement, In - it doesn't move at all. Tell me where I'm doing wrong
    154,508Coins
    +11,184 / 57 / -2
    Can you please post pictures of all of your settings, as I can't see them clearly in the video.
  8. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    All settings are exactly as in the video
    I can take my screenshots and it will be the same
    154,508Coins
    +11,184 / 57 / -2
    You really should do SMC3 settings specifically for your hardware, you will get better results that way.
    That aside please do post pictures of all of your settings, when you have the time, as something is odd.
  10. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    But in SMC3, the motors work correctly, but in SimTools they don't work. Do SimTools photo settings? Thank you for your patience
    154,508Coins
    +11,184 / 57 / -2
    Please post pictures of all SimTools settings, as something is likely not configured properly.
  12. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    I didn't make any other settings
      87.4 KB
      254
      225.4 KB
      456
      238.4 KB
      277
  13. noorbeast
    154,508Coins
    +11,184 / 57 / -2
    It looks like SMC3 is set to com port 5, but SimTools is set to com port 1, they should match, so change SimTools Com to 5:
  14. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    Yes, I changed it when I rebuilt it. I have COM 5 there when COM1 motors don't work at all. I took the wrong screenshot, excuse me
  15. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    when I make settings in SMC3, are they saved to the arduino sketch? After all, to run simTools, you need to disable SMC3 because they cannot both join to the same port
  16. noorbeast
    154,508Coins
    +11,184 / 57 / -2
    Yes the purpose of the SMC3 utility is to configure the settings, which are saved to the Arduino.
  17. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    I thought so, you confirmed my thoughts. Thanks!
  18. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    our dialogue was moved to a separate topic, did I understand correctly?
    154,508Coins
    +11,184 / 57 / -2
    Yes, a dedicated thread was created to assist you to resolve your configuration issues, as doing to was off topic for the build thread of another member.
  20. radist07
    radist07 Valeriy
    Учитель
    Россия
    630Coins
    Good day! Maybe SimTools doesn't work correctly with Windows11?
