My first 2 DOF
Discussion in 'DIY Motion Simulator Projects' started by FLORIN ROMANIA, Jan 23, 2023.
  1. noorbeast
    153,950Coins
    +11,159 / 57 / -2
  2. FLORIN ROMANIA
    FLORIN ROMANIA Member
    România
    810Coins
    Ok, I changed the local settings, now it works in LFS, but not in f1, when I stop the game from simtools, simtools closes
  3. FLORIN ROMANIA
    România
    810Coins
    Could it be from the game?
  4. FLORIN ROMANIA
    România
    810Coins
    When I do axis testing in f1, everything goes perfectly
    153,950Coins
    +11,159 / 57 / -2
    Thanks for confirming that, that the language bug seems to persist with SimTools v3 is something @yobuddy can consider further.
    If it works OK in LFS it is likely settings need to be refined for F1. If SimTools crashing on closing a game how are you actually doing the closure?
    And can you please post pictures of all you F1 settings.
  6. FLORIN ROMANIA
    România
    810Coins
  7. FLORIN ROMANIA
    România
    810Coins
  8. FLORIN ROMANIA
    România
    810Coins
  9. FLORIN ROMANIA
    România
    810Coins
  10. FLORIN ROMANIA
    România
    810Coins
  11. FLORIN ROMANIA
    România
    810Coins
    What is the max value In the tuning setting?, because I tried to increase the value to 50%, but I noticed that it goes way over 50
  12. FLORIN ROMANIA
    România
    810Coins
  13. FLORIN ROMANIA
    România
    810Coins
    And I can't save the values
    153,950Coins
    +11,159 / 57 / -2
    Try Capturing the Max/Min values then save.
    Also try reducing the Profile Intensity, say to 96 and see if that stops the crashes.
  15. FLORIN ROMANIA
    România
    810Coins
  16. FLORIN ROMANIA
    România
    810Coins
  17. FLORIN ROMANIA
    România
    810Coins
    I tried to increase the value in tuning but still not working
  18. noorbeast
    153,950Coins
    +11,159 / 57 / -2
    You need to capture the Max/Min values and the tweak from there.
    The smaller the value the snappier the response over a smaller range, the bigger the value the more gentle the response, over a greater range.
  19. FLORIN ROMANIA
    România
    810Coins
    I solved the problem, I downloaded the f1 2019 plugin and now it works, my opinion is that there is something wrong with the f1 2020 plugin
  20. FLORIN ROMANIA
    România
    810Coins
    Now I just need to put shocks absorber and springs, my rig is shaking a lot.
