Question motor movement problems with arduino and H bridges (code 2)
Discussion in 'DIY Motion Simulator Projects' started by Gigino83, Mar 21, 2023.
  1. Gigino83
    Gigino83 Member
    205Coins
    I don't understand why I can't get everything to work well, I'm trying to do a miniature test by following all the instructions, for the moment I have connected 2 motors powered separately at 6v and joined them using 3D printed supports to potentiometers 10k, when I connect the arduino to the usb and power the motors, it starts immediately to make small quick movements, and if I open smc utility it stops for a moment and then starts again. does not make longer movements!
    152,977Coins
    +11,116 / 56 / -2
    Please post pictures of all of your SMC3 settings.
  3. Gigino83
    Gigino83 Member
    205Coins
    At the moment I don't have a pc because during the tests I accidentally gave 10v to the usb and it doesn't work anymore.. but it's normal that even if I don't open any program but only connect the arduino and the power supply, the motors move without stopping making small movements fast?
    152,977Coins
    +11,116 / 56 / -2
    It is impossible to guess what the motors may do without any idea of the settings controlling them, hence the request for pictures of all settings.
  5. Gigino83
    Gigino83 Member
    205Coins
    I found a picture in my phone while doing tests, these are the settings but I had also tried changing the parameters.
    152,977Coins
    +11,116 / 56 / -2
  7. Gigino83
    Gigino83 Member
    205Coins
    yes, I followed all the instructions, I also watched the tutorials and tried to do the same but my fear is that there are current problems because I tried to use only one motor and one potentiometer and I noticed that it worked better, I managed to make it move even with the sim tool which, on the contrary, did not work with 2 engines. I don't know how to share a video otherwise I could show you better what it does.
    152,977Coins
    +11,116 / 56 / -2
  9. Gigino83
    Gigino83 Member
    205Coins
  10. Gigino83
    Gigino83 Member
    205Coins
    152,977Coins
    +11,116 / 56 / -2
    The settings in the video looked to be copied from here, rather than being dialed in to suit your particular hardware:
  12. Gigino83
    Gigino83 Member
    205Coins
    so do you think it's just a settings problem? as soon as i get my pc back i'll try to change them. Thank you
  13. noorbeast
    152,977Coins
    +11,116 / 56 / -2
    Likely so, follow the recommended setup steps and report at what PWMmax value the motors start to move:
    Initial Setup
    I strongly recommend you follow the steps below if this is the first time you are using SMC3 with your simulator to reduce the risk of damaging anything.
    8. Set Kp to about 400
  14. Gigino83
    Gigino83 Member
    205Coins
    ok thanks, I try to do so hoping to be able to make everything go. then once i get the miniature test to work i will start making the real one.
