SimTools v3 Public Beta
  1. levers
    966Coins
    The traction loss in the V3 version works fine it's just the min/max settings are very different.
  2. yobuddy
    51,554Coins
    The plugin has no baring on the gain, but will take a look.
  3. yobuddy
    51,554Coins
    We found the solution and will push the fix out later today guys.
    Take care!
  4. yobuddy
    51,554Coins
    We Pushed a SimTools v3 update that contains the needed api dll's for the plugins listed below.
    FSX, Prepar3D and MFS2020 plugins updated and uploaded to the repo.
    After the SimTools update, these 3 plugins should work as expected!
    Take care,
  5. flipflop
    flipflop Member Gold Contributor
    Swansea
    382Coins
    3DOF, Arduino
    Just installed wrc generations and now trying to patch the game in simtools 3.
    it's asking me to select the wrc generations game save directory. I have played a couple of races in solo and career mode but can't locate the save directory. Anyone able to point me in the right direction?
  6. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    I just tried msfs 2020. I startup msfs and simtools plugin attaches to the running game. There are no errors but i am not receiving any data for motion. The microsoft simconnect is in the game plugin for for simtools V3.
    C:\Users\Name\AppData\Local\SimTools3\GamePlugins.
    I also restarted the pc after the update. Any Ideas why i have no data, Thanks :)
  7. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
  8. Djalma Ribeiro
    Djalma Ribeiro Member
    Drone Pilot
    Cuiabá, Brazil
    168Coins
    Please help me! I configured the interface and the engines, during the tests in SimToolsV3 they move but during the game they don't.
    PS. I'm double-clicking the PLAY button to start the game.
    PS2. In SimToolsv2 it works better with values at 200%. Do not worry about this.
  9. Djalma Ribeiro
    Drone Pilot
    Cuiabá, Brazil
    168Coins
    At Assetto Corsa it's ok
  10. richdelta9
    8,850Coins
    The patch folder is in Documents\MyGames\WRCG
  11. richdelta9
    8,850Coins
    Please uninstall MSFS 2020 plugin and then restart SimTools. Once restarted, install the MSFS 2020 plugin through the plugin manager in SimTools and see if you get movement.
  12. richdelta9
    8,850Coins
    Uncheck Auto Profile in the upper right corner and then try again.
  13. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    I have removed the plugin msfs2020, rebooted, reinstalled the plugin, placed the .exe onto the plugin as this is a non steam version and rebooted. When i use the plugin to start msfs 2020, msfs crashes half way through loading. I tried this several time to be sure, rebooting between tries. If I start msfs and let it load then start simtools v3 it will attach to the sim. But i still have no motion data input.
  14. yobuddy
    51,554Coins
    It can be the games exe or the shortcut you use to launch the game.
    Do you use the exe to launch the game? if not drop the shortcut onto the game banner.
    Other than that, we will just need to wait a bit for some more feedback and go from there.
    See if someone with the steam version is able to get it working.
    Take care,
  15. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    Ok, Just for your info, if I launch the sim and then simtools, it does attach to the game but with no data,
    thanks youbuddy :)
  16. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    I switched the exe from FlightSimulator.exe to gamelaunchhelper.exe and it will now launch the sim without crashing and attach to the sim, but no motion data.
    C:\Program Files\WindowsApps\Microsoft.FlightSimulator_1.31.22.0_x64__8wekyb3d8bbwe\gamelaunchhelper.exe
  17. yobuddy
    51,554Coins
    Awesome, thx for the info.
    Are you looking for motion data in the min/max tuning center?
  18. early_m
    early_m Active Member
    Chelmsford
    839Coins
    Can confirm it's working for the Steam version :cheers
  19. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    Yes, For some reason I'm not getting data to the motion input and I can't figure out why. It attaches to the sim ok but not retrieving the motion data
  20. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    Question....Has anyone got the non steam version of msfs 2020 working? thx
