SimTools v3 Public Beta
  1. Djalma Ribeiro
    Djalma Ribeiro Member
    Drone Pilot
    Cuiabá, Brazil
    168Coins
    It worked! Thanks
  2. Djalma Ribeiro
    Drone Pilot
    Cuiabá, Brazil
    168Coins
    Tip: Double-clicking the PLAY button is not very intuitive. A simple click makes more sense, or an enable and disable button.
  3. yobuddy
    51,521Coins
    This may be true, but it's really annoying to accidentally click play on a game that takes forever to load up, just so you can exit back out of the game.
    And double-clicking to launch something is pretty common.
  4. richdelta9
    8,850Coins
    I uploaded X-Plane 11 game plugin for V3.
    Let us know if you find any issues.
  5. Djalma Ribeiro
    Drone Pilot
    Cuiabá, Brazil
    168Coins
    it worked but it seems that it wasn't just that. It worked but not every time.
    The communication protocol was set to Project Car 2 in my AMS2. After I switched to Project Car 1, as it says on the plugin page, it seems to have solved the problem.
    It's funny because in Simtools v2 I used Project Car 2.
  6. yobuddy
    51,521Coins
    AMS2 can be used with both API's 1 and 2.
    The plugin will work with both.
  7. Djalma Ribeiro
    Drone Pilot
    Cuiabá, Brazil
    168Coins
    or it may have been resolved when I dragged the AMS2 shortcut from the desktop to the plugin.
    but it's weird because Simtools automatically detected when I started the game. So it didn't seem to be missing the link with the game.
  8. Djalma Ribeiro
    Drone Pilot
    Cuiabá, Brazil
    168Coins
    Yesterday I requested the creation of the "Hi Motion Racing" repository. You can authorize it, please.
  9. yobuddy
    51,521Coins
    This shortcut is only used when starting the game from SimTools v3.
    When using auto game detection, this link is not used.
    Take care,
  10. levers
    954Coins
    Hi Yobuddy,
    I was messing, again!, with the settings today and altered the parking then it crashed. Every time I altered or even removed it and pressed 'save and park' it crashed. Starting a game with parking removed and it crashed. the platform didn't need to be powered for it to crash and I tried various axes.
    However, I rebooted and it was fine so I don't know what was happening there. It also never crashed until I altered it. I thought I'd let you know.
    Is it possible to change the image or add some wording to the console plugin versions as they are exactly the same as the PC versions? Thanks.
  11. yobuddy
    51,521Coins
    Forza Horizon 5 posted for PC and Console. :thumbs
  12. yobuddy
    51,521Coins
    Hovering the banner will give you different play buttons, but you are correct.
    We plan to update the console ones or add a overlay or something.
    Forza Horizon 5 Console version has its own banner, as i had 2 on hand. :thumbs
  13. Karolis
    Karolis Pioneer
    Lithuania
    137Coins
    Ok i will solve the problem about f1 22 gears here. So it is very important that "UDP Broadcasting" should be OFF. Otherwise data become laggy. And some times you can feel gear change, sometimes not. I put picture just for clear view for other who has the same f1 22 gear problem.
  14. yobuddy
    51,521Coins
    You don't need to mess with any settings, as the plugin sets everything up for you buddy.
    Also, you will get a better ride with the Send Rate set back to '60'.
  15. yobuddy
    51,521Coins
    I will take a look. My guess is the JRK needs to be plugged into the PC and turned on, or not plugged into the PC at all.
  16. richdelta9
    8,850Coins
    You now have access.
  17. Mu-KwangKim
    South, Korea
    - 689Coins
    @yobuddy
    The value cannot be adjusted in the detailed menu such as the filter, outputtype... and is fixed to the medium value. It used to work, but I can't control it after the update.
  18. yobuddy
    51,521Coins
    No sure where your talking about buddy.
    All updates in the last couple of weeks has just been for game plugins, so not sure where to look is all.
  19. Mu-KwangKim
    South, Korea
    - 689Coins
    ok.
    I recorded it as a video.
  20. Moppi07
    Moppi07 New Member
    - 4Coins
    2DOF, JRK
    For me in v3 it works only with pcars1.
