Problem with motor
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Simone86C, Mar 26, 2023.
  1. Simone86C
    Simone86C New Member
    3Coins
    Good morning everyone,
    I'm building my first 2DOF platform but I'm having problems with the engines.
    My setup is as follows:
    - N°2 motor Motion Dynamics 12V, 200W, 180 RPM, 20Nm.
    - N°2 PSU Meanwell 12V, 320W
    - N°1 Arduino Uno R3
    - N°2 IBT-2 ( BTS7960B 43A)
    I did some tests with SMC3 and everything seemed to work but, the next day, both motors stopped moving.
    I assumed the motors were damaged and tested them separately from the rig and they work.
    I bought two more IBT-2 boards, installed them, but nothing changed.
    I don't know what it could be that's not working anymore.
    I am attaching some images of the test screen, of how I wired the boards and the Arduino code. Please give me a hand. Thanks to anyone who helps me. Cattura.JPG A.jpg B.jpg C.jpg
    153,950Coins
    +11,160 / 57 / -2
    Double check the port is correct in Device Manager.
    Is the Arduino genuine or a clone?
  3. Simone86C
    3Coins
    Thanks for your help.
    Arduino is genuine and i check the COM port and it is correct.
    I have attached the image for the COM ports and everything seems ok. I have also attached the Arduino file that I uploaded.
    153,950Coins
    +11,160 / 57 / -2
    Following the SMC3 setup steps if you increase pwmmax further, as yours is set very low, do the motors start to move:
    8. Set Kp to about 400
  5. Simone86C
    3Coins
    I re-ran the procedure you described and increased PWMax up to the allowed limit but nothing changed.
    The engines continue to stand still. As soon as I increase PWMax, I only hear for a moment a small noise from the engine, as if it wanted to turn.
    153,950Coins
    +11,160 / 57 / -2
    Presuming SMC3 has been correctly installed that suggests a hardware fault, either the arduino or control boards.
  7. Simone86C
    3Coins
    That's what I suspect too. I exclude the control boards considering the fact that I have a total of 4 new ones and the motors still don't work.
    Tomorrow I get a new ARDUINO and I'll try.
    I'll let you know.
    153,950Coins
    +11,160 / 57 / -2
    I asked earlier if the Arduino is a clone because clones are known to have issues, but it is rare for a genuine Arduino to be faulty, though not impossible.
