  1. Don Weatherby
    Don Weatherby New Member Gold Contributor
    - 49Coins
    153,734Coins
  3. Don Weatherby
    - 49Coins
    OK Thanks i will check that out.
  4. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,035Coins
    3DOF, DC motor, Arduino, 6DOF
    This is what I have. It does not mean it is the best setup, but it seemed to work.
    Pierre.
    153,734Coins
    I doubt PWMmax and PWMrev values need to be that high, but the rest seem to be pretty sensible.
    My guess would be try PWMmax and PWMrev at 120-150 and run Sine to see how well it tracks.
  6. Don Weatherby
    - 49Coins
    Thanks so much. im doing some experimenting to see how that helps.
  7. ampcode
    ampcode New Member
    17Coins
    Can someone explain me difference between Target sent and Target recv plot? light and dark blue?
    And why for some those are equal and for some, like me, they are not?
  8. Fred Bear
    Fred Bear New Member
    Engineer
    148Coins
    Hello All
    I'm hoping for some advice.
    SMC3 ver 13.07 ( Its a DOF reality M2 that I have modified and upgraded into a 2DOF platform).
    All is working, but I cannot get the SMC3 limits to change.
    Example - POT feedback is - Up limit is 3.3 volts. Mid point is 2.5 v and lower is 1.8v.
    It does not matter what numbers I set for Max limits and Clip input, the servos will only drive to these max and min feedback (pot) voltages. IE 3.3V Max, 1.8V Min.
    I am wondering if the SMC3 loaded into the Arduino has the max limits and clip inputs locked ?
    Am I correct to say that with the limits set to max, the servo should drive to virtually 0 and 5 volts of POT feedback ?
    Many thanks.
    Warren.
    153,734Coins
  10. Fred Bear
    Engineer
    148Coins
    Hello Noorbeast
    The control box is a DOF Reality M2
    I used DOF Reality tools to do their firmware update.
    Their SMC3 utils is called Ver 1.02, But it says Ver 1.01 on its screen.
    Can you advise on how to adjust range for servo feedback ?
    Currently the servo moves 100% + is 3.3 volts, and 100%- is 1.8 volts.
    I'm looking to use a range of something like 0.5 to 4.5 volts.
    Many thanks.
    Warren.
  11. Fred Bear
    Engineer
    148Coins
    I just uploaded a screen shot
  12. Fred Bear
    Engineer
    148Coins
    Well, for anyone who may find this useful..
    Dof reality's version of SMC3 has a lot of the parameters locked..
    (Side note...
    1.. It appears there is no easy way to backup software already loaded on an Arduino Uno R3..
    2.. the DOF Reality tools will NOT reload their version of SMC3 if you load the normal version 1 - not a problem for me, but be aware... Balance function will also NOT work).
    So, I compiled and loaded SMC3 VER 1 .0..... Set up parameters as I wanted, and all is good. I can now get full travel on my servos.
    Best regards.
    Warren.
  13. Bagslo
    Bagslo New Member
    - 20Coins
    Hi, I am working on a 2DOF and Built the control part with unoR3 and IBT-2
    when trying to use SMC3 utility to find the right parameters I met the following problem: after the utility establishes connection with the Arduino board I cannot turn on any of the motors, all appear turn in off and cannot be on again!
    Any suggestion?
  14. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,035Coins
    Are your potentiometer at the middle? If not, they trigger the safety stop.
  15. Bob the builder
    Bob the builder New Member
    120Coins
    where can i find the links to order everything? or could someone help me with this becouse i want to make sure i order the correct parts
  16. Bagslo
    Bagslo New Member
    - 20Coins
    My potentiometer îs the green line
  17. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,035Coins
    It should be in the center as your actuator is in the center and follow along. In this video, my actuator is a bit up and so is the green line.
  18. ChuckyP
    ChuckyP Active Member
    Chicago, IL
    748Coins
    It does appear as Pierre mentioned that the potentiometer is not centered and is outside the safe limits which will cause the motors to shutdown. With your motor arms centered you need to turn the potentiometer until the green line matches the blue line. Make sure you followed the instructions for setup and limit the power going into the motors until you verify the wiring is correct, or the motors can run away on you.
  19. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    Is it possible to run dual Uno's in SImtools V3? I want to run 4 motors.
    153,734Coins
    Yes you can, even more Arduinos if you want to.
