Hot motor.
Discussion in 'Commercial Simulators and Peripherie' started by TwinPainter, Apr 4, 2023.
  1. TwinPainter
    TwinPainter New Member
    Retired.
    UK.
    94Coins
    I dont know if i'm posting in the right place,i'm very dismayed.I bought a used DOF H3 motion platform,i've just finished building it up.I thought i'd try it out in MSFS,it was a bit juddery.Anyway i did two laps round the airport and i could smell burning.I felt the right motor and it was ok,felt the back motor that was ok.When i felt the left motor it was hot,that's where the burning was from.I'm gutted.
    153,001Coins
    +11,116 / 56 / -2
    Does the motor still run once it cooled down?
  3. TwinPainter
    Retired.
    UK.
    94Coins
    Not tried it yet,i came straight down and posted my thread.It was really hot,gonna have to leave it a bit longer.
  4. Gadget999
    12,072Coins
    does it get hot with no load on the sim ?
    is the sim balanced correctly ?
    how much weight is it lifting ?
    153,001Coins
    +11,116 / 56 / -2
  6. TwinPainter
    Retired.
    UK.
    94Coins
    Yes its ballanced,i've only got my yoko yoke,virtual fly throttle quadrant and saitek control and switch panel and my keyboard.I noticed the left motor juddering even on the way down,none of the other motors get hot.
  7. TwinPainter
    Retired.
    UK.
    94Coins
    153,001Coins
    +11,116 / 56 / -2
    If it does run you probably should still strip that motor down and check the windings and brushes.
  9. Gadget999
    12,072Coins
    does it use potentiometers for location ?
    you may be able to swap the motor from left to right and see if the problem still exisits
  10. TwinPainter
    Retired.
    UK.
    94Coins
    It does run,i moved my seat back to take a bit of load of the front.Its still juddery and still gets warm,the other motors don't get warm at all.As for stripping it down,i'm going to do some studying on youtube.
  11. TwinPainter
    Retired.
    UK.
    94Coins
    I know nothing about potentiometers,i really am a dummy to sims.It shouldn't be juddery though,should it.
    153,001Coins
    +11,116 / 56 / -2
  13. TwinPainter
    Retired.
    UK.
    94Coins
    Yes,the hot one.I've checked the ballance,my seating position is in the center of the universal joint or gimble is it.Just watched this vidio on ballancing,i will try and post a vidio later to show the juddering.Thanks.
    153,001Coins
    +11,116 / 56 / -2
    Balance is determined with you sitting in the rig and all peripherals attached, with the motors disconnected and a good friend helping to steady things if needed.
  15. TwinPainter
    Retired.
    UK.
    94Coins
    Decided to take the motor off the back,swap it round and get the hot one rewound.That way i'll still have a 2 dof for the time being,i did price one up from Dof reality.$300.00 pluss shipping,it's cheaper to get it fixed.
