Tutorial SimTools v3 - RPM Dash Example (with Arduino Sketch)
Discussion in 'Tutorials and Tips by the Developer' started by yobuddy, Apr 26, 2023.
  1. yobuddy
    51,545Coins
    Here is a good example of how to use the dash feature found in SimTools v3.
    (Special thanks to @early_m for helping with this post!)
    Below you will find a wiring diagram, a sketch for an Arduino, and instructions to turn an addressable led strip into a RPM bar. The Sketch is setup to use a WS2812B led strip, but anything compatible with the FastLED Arduino api will work as well.
    Here is the led strip wiring diagram:
    RPM Arduino Sketch:
    RPM.zip
    Once the file is opened, be sure to set the settings below.
    - the number of led's in your led strip.
    - when color#2 starts
    - when color#3 starts
    - max brightness of your led strip (255 is max)
    - the pin number for the led strip to connect to.
    And you can edit the 3 colors you want to use in your strip here
    (It's RGB values where 255 is max and 0 if off)
    Then upload it to the Arduino you are golden!
    SimTools v3 setup.
    Go to the interface settings and connect your new led bar
    Then go to the edits for rpm and set the command GetBits 0 9000 8 b, where 9000 is the max rpm you want to use for the profile.
    And lastly, tell SimTools what to send for output
    That's it, now run the game and enjoy!
    153,950Coins
    +11,159 / 57 / -2
  3. hansvdm
    hansvdm Member
    Freelance
    leiden Netherlands
    111Coins
    What values do I have to change ?
    I have led strip with 72 leds, Using RaceRoom game. When I start the game 12 leds (all green) lit up. More rpm the blue light up (20 leds are green, and after 20 blue leds lit up and then red lit-up max 6 red leds.
    so the maximum number of leds that lit up is 46 while I ave 72 leds :)
    I want default 3 leds on, then with higher rpm 25 green on, than 30 blue and than 17 red when rpm is max.
    thanks for any help on this
    Hans
    @yobuddy
  4. yobuddy
    51,545Coins
    If you have set the proper settings in the sketch here:
    if you still don't get all led's on, take a look at the Hi/Low settings for rpm for the game.
    My guess is the Hi values is to Hi is all.
    Let me know how it goes buddy!
  5. hansvdm
    hansvdm Member
    Freelance
    leiden Netherlands
    111Coins
    thanks for the tip
    I have Race Room Experience and used this settings: Getbits 1550 5500 8 b. The ledstrip works great now. By default 1 led is on and with full RPM all 72 leds lit up.
  6. aparecido
    aparecido diy 2dof for flight simulator 2020
    MECHATRONIC TECHNICIAN
    BRAZIL
    - 51Coins
    Does the sketch go with the dof 2 sketch?
  7. yobuddy
    51,545Coins
    You would use another Arduino for this, not combine it with the motion side of things, if that is the question?
  8. aparecido
    BRAZIL
    - 51Coins
    Yes, my question would be this, do I have to use another Arduino? Another question is how is the acceleration signal recognized?
  9. aparecido
    BRAZIL
    - 51Coins
    From what I understand, the signal is recognized by the serial port.
  10. yobuddy
    51,545Coins
    Yes, as Dash and Motion interfaces are separate.
    We are using the RPM output from the Dash section.
  11. aparecido
    BRAZIL
    - 51Coins
    Thanks for the info
  12. RJ Stausebach
    RJ Stausebach Member Gold Contributor
    Ireland
    315Coins
    Hi @yobuddy , Thanks for this example. I am trying to use the same settings I had in Dash for Simtools 2.x in the MSFS2020 plugin that drives a force feedback actuator (based on airspeed) and a wind generator (based on RPM) in the Dash for Simtools v.3 for the MSFS2024 plugin.
    The FS2020 version relied on the converting of the return to HEX. This code is no longer accepted in the V3 FS2024 by the looks of it? So in the Output Rules it does not accept the TOHEX statement. What code should be used now please?
  13. yobuddy
    51,545Coins
    @RJ Stausebach,
    I will take a look, and make sure ToHex is in the next release.
    For now I believe you can use: GetBits 0 255 8 H
  14. RJ Stausebach
    Ireland
    315Coins
    Many thanks @yobuddy !
    Will try that this weekend and let you know.
  15. RJ Stausebach
    Ireland
    315Coins
    Hi @yobuddy , so gave it a try. That did not work. Let me qualify, the Airspeed (still) works (it worked before without the Hex code). The RPM still does not work. I suspect that the MSFS2024 plugin may not be identifying the RPM correctly? I am looking for the Prop 1 RPM. It worked in the MSFS2020 plugin. For the MSFS2024 plugin you do not specify what RPM it is looking at?
    At 8 bits the 255 is not enough to cover the expected 3000rpm range, I can see that using 16 bits my max RPM is showing around 32000. So it is picking up something but not sure what. My range, converted to Hex, would need to be between 0 and 3000. What coding would achieve this?
    Thanks,
    Roel
    ps. the Virtual Output confirms that speed is being read and RPM maxes out at 255.
  16. RJ Stausebach
    Ireland
    315Coins
    This is the screenshot for virtual window
  17. yobuddy
    51,545Coins
    The 2024 plugin is using RPM 1 for the input.
    Code:
      MFS2024_simconnect.AddToDataDefinition(DEFINITIONS.Struct1, "PROP RPM:1", "Rpm", SIMCONNECT_DATATYPE.FLOAT32, 0!, 10)
    I finished adding ToHex to the dash output commands this weekend. I have a few more things to do and will then push the update out (probably later in the week).
    Take care! :thumbs
  18. RJ Stausebach
    Ireland
    315Coins
    Thanks @yobuddy , Perfect!
  19. RJ Stausebach
    Ireland
    315Coins
    @yobuddy Hi Dustin, just checking in to see if this update is still coming?
    Also, would it be possible to pick up Airspeed rather than groundspeed in MSFS2024 Dash? I use it for airflow effect on the flight controls, so could be screaming down in a vertical dive and have nil groundspeed?
    thanks,
    Roel
  20. yobuddy
    51,545Coins
    I will push the update out on Wednesday. For MSFS2024 I can take a look if airspeed is available to add.
    • Optimistic Optimistic x 1
