FlyPT set up with DC Motor and Double BTS7960 drive
Discussion in 'DIY Motion Simulator Projects' started by Flymen, Apr 13, 2023.
  1. Flymen
    Montreal, Canada
    2,432Coins
    DC motor, 6DOF
    Hello everyone ,
    I am on my second assembly with the FLyPT set up (ESP32) activated by opto and relays to control the output signal , but this time, I control the Double BTS7960 drive with 2-pole Magmotor motors and it works quite well.
    ESP32 module accepts feedback from 500 p/r encoders and does 'nt seem to jump step with two motors on ESP32 module.
    However, I have two problems now :
    1-Dc motors make Harmonic noise (see video)
    2- When the actuators are moving, I have small vibrations or ripples in my signal to the motor , with some filters and lower PID it helps but not enough. The best frequency on Esp32 Sketch found is: #define PWM_FREQUENCY 5000 because higher or lower , the motor makes more noise. ( see video )
    Thanks for your help !!
    @pmvcda
    Vibration from PWM signal - YouTube
    Vibration from PWM signal ? - YouTube
  2. Flymen
    Montreal, Canada
    2,432Coins
    DC motor, 6DOF
    Hi ,
    This video is a good exemple for problem with harmonic sound from DC motor .
    Control Large Gearmotors with PWM & Arduino - YouTube .
    DC Drive with one direction input and one PWM control ....Cytron 13 A DC MD10C .
    This drive seems good .... with the ESp32 driver from FlyPt Sketch , I don't need relay and opto for this drive and maybe less problem of harmonic and vibration from my output signal , but more expensive like 50-75 $can instead of 4$can for the BTS7960 .. Mmmm I'm going to buy one to see the difference
    Pilote moteur Cytron 13 A DC MD10C : Amazon.ca: Outils et Bricolage
    or
    Pilote De Moteur Md13s-cytron 13amp - Câble Enrouleur - AliExpress
    and cheaper one BTS7960 :
    Double BTS7960 – module de commande de moteur haute puissance 43A, pont en H, pour voiture intelligente, outil de diagnostic de courant, à faire soi même | AliExpress
    FLyPt Sketch : Showroom - FlyPT - 6DOF Brushless DIY Actuators (xsimulator.net)
    See: Code for ESP32 with internal PID calculation, version: 11.3.is from 17-04-2020:
  3. Flymen
    Montreal, Canada
    2,432Coins
    DC motor, 6DOF
    Hi , ( Problem number two ) @pmvcda
    After somes test , you will see on this video , with the FlyPt Mover program that when I select Icon * Rigs * my vibration come from there !!!! And I don't know why ..... missing ground led ???... or somethings else o_O
    and when I Hide this page * Rigs * everithing is fine ! Realy strange
    (1) Vibration with Dc Motors and FlyPt mover - YouTube
  4. ahoenksiluman
    ahoenksiluman Member
    indonesia
    89Coins
    maybe you can try arduino uno with smc3 firmware
    it works well for me, and it have lots of adjustment
