3DOF+loss traction for cars and anything that flies
Discussion in 'DIY Motion Simulator Projects' started by Kenshiro27, May 1, 2023.
  1. Kenshiro27
    Kenshiro27 Active Member
    70Coins
    After having read a 2dof simulator here is my new 3DOF simulator + loss of traction
    To do this I used this site. Here are the two links:
    -https://pcshm-simulateurs-homemade.clicforum.com/t836-Guide-de-r-alisation-d-un-simulateur-de-pilotage-3DOF-moteurs-350w.htm
    -https://pcshm-simulateurs-homemade.clicforum.com/t1137-tuto-pour-les-nouveaux-explication-lien-sch-ma.htm
    And of course xsimulator with the help and kindness of @noorbeast and @yobuddy
    as well as all users and feedback from all these members
  2. Kenshiro27
    70Coins
  3. Kenshiro27
    70Coins
  4. Kenshiro27
    70Coins
  5. Kenshiro27
    70Coins
  6. Kenshiro27
    70Coins
    I remain at your disposal for any questions that could help you in your future or current project.
  7. Kenshiro27
    70Coins
    I fixed the connecting rods, adjusted the height of the plate and made the settings in simtools. I still have to fine-tune the settings because the 400W motors are really more powerful than the 120w of my 2DOF. I understand why an emergency stop and strongly recommended:grin
  8. Kenshiro27
    70Coins
  9. Kenshiro27
    70Coins
  10. Kenshiro27
    70Coins
    And for those who are interested, I also made a fanatec compatible usb steering wheel. With 3d printer. IMG_20230506_093723.jpg
  11. Kenshiro27
    70Coins
    I install a seat belt, which for this type of simulator is really necessary. On spring to simulate the tension of the latter during heavy braking
  12. Kenshiro27
    70Coins
  13. Kenshiro27
    70Coins
  14. Kenshiro27
    70Coins
    Can be completed the simulator with bass shaker enclosure coupled with sim vibe
  15. Kenshiro27
    70Coins
    Here is the installation of a vibration system that I installed recently
    I used bass shakers which are easily found on the internet for around €25 each
  16. Kenshiro27
    70Coins
    and an amp which can also be found for around €40
    either all with cable for around 100€ and it's really interesting
  17. Kenshiro27
    70Coins
    This brings a lot to the simulation because with simvibe you can adjust a lot of parameters such as collision, engine revolution, gear change and others. I recommend it to everyone
  18. noorbeast
    152,003Coins
    +11,061 / 56 / -2
    I also use those small Nobsound amps, using slip in 3D printed bracket holders for them.
  19. Kenshiro27
    70Coins
    Interesting
    I have to move in two months and finally place my simulator in a dedicated room permanently. At that time I will do a clean installation in terms of cables and boxes. Your 3D file if you will give it to me will be very useful to me;)
  20. Airbas72
    Airbas72 Member
    - 7Coins
    3DOF, Arduino
    Hello, I have a question - do springs improve the performance of the platform? I'm currently looking through a lot of information to choose for myself which drive is better for 3 DOP.
