Showroom My 6 DOF with full 360.
Discussion in 'DIY Motion Simulator Projects' started by Hieu Nguyen, May 3, 2023.
  1. Hieu Nguyen
    Hieu Nguyen New Member
    - 39Coins
    Hi everybody.
    this was completed last month.
    it still needs to be
    more perfect.
    • Winner Winner x 3
    153,950Coins
    +11,159 / 57 / -2
    Awesome job :thumbs
    Can you give a bit more detail about the rotation design and implementation?
    I am also curious, given the relatively narrow base is it bolted to the floor?
  3. Hieu Nguyen
    - 39Coins
    yes, it is slid to the floor by 4 12mm bolts.
    The Rotary is used with a 1:160 size 45 harmonic gearbox.
    This is first design.
  4. Hieu Nguyen
    - 39Coins
  5. Hieu Nguyen
    - 39Coins
  6. Hieu Nguyen
    - 39Coins
    I use slip ring to prevent cable kink
