Showroom DIY 2DOF simulator
Discussion in 'DIY Motion Simulator Projects' started by Erwan960, Sep 27, 2013.
  1. wp8051
    wp8051 Racing simulator player Gold Contributor
    China
    234Coins
    AC motor, Motion platform, 4DOF
    Hello, thank you very much for your reply.
    I'm in China now, and I found a similar reducer shaft on the shopping website here.
    This shaft contains gaskets, circlips, and flat keys.
    If I process the rotating part according to the drawings you provided, and then buy a shaft of a reducer with a suitable size, can they be installed together?
    There are pictures of the kind of shaft I found in the attachment. There are many different models. Fortunately, there are threaded holes on the end of the shaft.
      150.2 KB
      489
      73.8 KB
      501
      63.4 KB
      481
      233.1 KB
      501
  2. cityparker
    cityparker Member
    125Coins
    2DOF, DC motor
    Thanks for posting that, it will make setting up my own JrKs much easier. Something I need to get around to eventually as I want to use my Arduino on my next project.
  3. lttjun
    lttjun New Member
    74Coins
    4DOF
    i 'm think about what will happen if a very very large man sit on it ? can it work nomal?
    151,644Coins
    +11,044 / 56 / -2
  5. Abram Manoge
    Abram Manoge Member
    Web developer
    South Africa
    319Coins
    What is the distance between the bottom board to the top board?
  6. cqcretador
    cqcretador New Member
    29Coins
    Hi Erwan, how did you stabilize the simulator at 90°?
  7. Erwan960
    Erwan960 Active Member Gold Contributor
    3,832Coins
    Just use non-reversible reducers.
  8. sci666
    1,208Coins
    mhhh nice video but the monitor placement ..idk ..... very strange - half of the screen is concealed by the wheelbase and dash ....
  9. Erwan960
    3,832Coins
    A 43" screen placed for a perfect overlap with the steering wheel and dashboard.
    So, half of the screen is not concealed but in perfect position to match with reality.
    No need to shift it upwards to see a black roof that we already perceive widely.
  10. sci666
    1,208Coins
    Yes but in this way you cover the original Onscreen gaugecluster with your wheelbase dash . This would not be my favorite... If I drive a specific car I Wanna see the original gauges... But when it's okay for you everything is fine
  11. Erwan960
    3,832Coins
    Indeed, it was perfectly the objective to cover the original dashboard since it is the same on the M4 or the 296.
  12. Opast
    Opast New Member
    Chicago, USA
    132Coins
    Where did you buy u-joint part?
  13. noorbeast
    151,644Coins
    +11,044 / 56 / -2
  14. sci666
    1,208Coins
    a good source for these things is a car scrap yard or ebay :D search for carparts and steering paarts
