Question help please
Discussion in 'Off Topic - All other stuff here' started by Tricky, May 11, 2023.
  1. Tricky
    Tricky New Member
    36Coins
    Hi Guys, im new to forum but have issue with game manager not connecting to game engine, could anyone possibly explain why this isnt connected and how i might resolve the issue
    thanks in advance Andy
    153,950Coins
    +11,159 / 57 / -2
  3. Tricky
    Tricky New Member
    36Coins
  4. Tricky
    Tricky New Member
    36Coins
    obviously this needs to say connected or the seat doesnt work
    153,950Coins
    +11,159 / 57 / -2
    I presume you have a licensed version of SimTools?
    Is the game correctly patched for motion?
    Have you first created and tested a Default Axis Assignment then created one for pCars2?
    What motion rig are you using and does it work as expected in Output Testing?
    In addition to the SimTools related questions PC2 requires in-game setting configuration, has that also been done: https://www.xsimulator.net/community/faq/projectcars.188/
  6. Tricky
    Tricky New Member
    36Coins
    yes everything is setup correctly as the seat was working and the output testing is fine, the only thing that is different is this issue saying not connected
    seat worked perfectly last time i used it
    153,950Coins
    +11,159 / 57 / -2
    What brand of computer do you have?
    What has changed on that computer since the last time it worked OK, any update or new installs?
