2DOF D.I.Y
Discussion in 'DIY Motion Simulator Projects' started by art031515, Jun 10, 2023.
  1. art031515
    art031515 New Member
    161Coins
    Try adding some more FFB handlers.
    Arduino and motor driver connection
    3D phase after the player to connect the variable resistor connection parts
    SMC3 test
  2. art031515
    161Coins
    0623 U-joint DIY
    30x30 aluminum profile frame
  3. iason
    iason Member
    - 13Coins
  4. art031515
    161Coins
    The steering wheel used a 775 motor, encoder last year and printed a 3D printer.
    Recently, I made additional vibration speakers and wind motors with SimHub, and I joined because I wanted to make motion.
    Wow your motion is very nice and scale.
    I'm trying to make it small because the space is small, but the production is so much fun, but there are also many difficulties.
  5. art031515
    161Coins
    Today, following yesterday, I completed the frame and made a bracket for fixing the motor.
    In order to make the most of the materials we have, we are designing and proceeding with sketch-up in advance.
  6. iason
    iason Member
    - 13Coins
    thanks! totay at last i solved the proplem that i have with my rig! it was a bug on simtools with unicode on my pc. https://www.xsimulator.net/community/faq/simtools-language-setting-bug-change-to-english-local.233/ this one. the guys here help me a lot ,they found it. im sure your motion rig will be great! you got it!! i will follow your progress
  7. art031515
    161Coins
    The delivery of the end rod bearing was delayed, so I made a power supply today.
    I put a boost circuit in my power supply for 12V and convert it to 24V
    Sketch-up modeling to determine the exact location before punching the PowerSafly steel plate cover
    Bolted after drilling on steel plate
    Attach two motor drivers and Arduino nano to the top of the power supply cover
    All wiring was worked with connectors to prevent poor contact.
  8. art031515
    161Coins
    CNC machining of variable resistance bracket
    Rod end bearing Assembly
    [SMC3 test]
    Unfortunately, one motor failed, and the other is not available until next week
    [Game test]
    Video editing error caused the two images to be out of sync.
  9. art031515
    161Coins
    One of the motors is broken, so to obtain the same motor, disassemble one of the products, and then accumulate the motor
    It takes some time to remove almost all accessories to remove all accessories.
  10. art031515
    161Coins
    Motor rotation shaft to end rod bearing connection
    Replace one failed motor
    Setting is complete
    35% setting
    Test motion video
  11. ChuckyP
    ChuckyP Active Member
    Chicago, IL
    748Coins
    Looks good. Way to overcome the hurdles. I like the “Brain” box setup.
  12. art031515
    161Coins
    Thank you for liking it.
    I still have a lot to do, but I feel good because it works.
  13. art031515
    161Coins
    peddled DIY
  14. art031515
    161Coins
    I've done so many LFS demo versions that I don't even want to think about it anymore, so I hope it becomes a month soon and I apply for a DIY license.
    152,553Coins
    +11,086 / 56 / -2
    You applied for a DIY license in conjunction with your first post on the 10/6, having joined on the 7/6, and it was rejected as it did not meet the eligibility criteria at that time. You will need to reapply once all aspects of the criteria are met:
    To qualify for a free license:
    • You must be building a true DIY motion simulator. (Not built from a kit or purchased from a simulator seller, a model simulator does not qualify.)
    • Have a unique build thread or Showcase in DIY Simulator Projects. (The thread should show some effort, which means it should show progress to the rig testing phase.)
    • Have been a member of the community for at least 30 days.
  16. art031515
    161Coins
    Can't simtool and simhub be used at the same time? Each works well individually, but when I run both, I think there is a port collision, so I did port forwarding on simhub, but simtool doesn't work. Can't it be a demo version?
    LFS>>simhub (port relay)>>simtool
    Is this the right way?
  17. art031515
    161Coins
    Can I apply again after a month?
  18. noorbeast
    152,553Coins
    +11,086 / 56 / -2
    You sure can!
    I have not used it with LFS but perhaps the FAQs can help you figure port forwarding out for LFS: https://www.xsimulator.net/community/faq/simhub-port-forwarding.356/
  19. art031515
    161Coins
    Output the motor bracket to the 3D printer
    Add one more motor on the handle
    120mm fan for motor and gear heat dissipation
  20. art031515
    161Coins
    Separate the sheet from the frame
    Seat Combination
