Grand Theft Auto 5 ScriptHookVDotNet3 plugin
Discussion in 'SimTools Plugins' started by knaufinator, May 18, 2020.
  1. knaufinator
    knaufinator Active Member
    Simulation Engineer
    akron,ohio
    1,874Coins
    AC motor, 6DOF
    not while I am at work, I can later,. but you should be able to search for them, install them into your gtav directory
  2. zhai1987
    zhai1987 Member
    320Coins
    2DOF, 3DOF, AC motor
    Script Hook V + Native Trainer 1.0.2944.0
  3. zhai1987
    zhai1987 Member
    320Coins
    Is this suitable?
  4. zhai1987
    zhai1987 Member
    320Coins
    Version
    151,979Coins
    +11,061 / 56 / -2
  6. knaufinator
    Simulation Engineer
    akron,ohio
    1,874Coins
    AC motor, 6DOF
    install this,
    http://www.dev-c.com/gtav/scripthookv
    and this
    https://www.gta5-mods.com/tools/scripthookv-net
    then place my GTAScriptHookPlugin in the gtav "scripts" folder, you need to create the folder..
    you can verify the plugin is at least being run by looking at the scripthookdotnet.log file that should be getting created in the gtav folder when you run the game, this will log errors or success when loading my script.
    the plugin sends data over UDP to the simtools plugin
    I do not have gtav installed so I cant check if this still works,.. but as long as scripthook and scripthookdotnet are working, this plugin should.
    * I am currently working on a Red dead Redemption 2 plugin that operates in the same fashion (easy as its the same game engine),... for horse back riding,... lol
  7. ChuckyP
    ChuckyP Active Member
    Chicago, IL
    748Coins
    Might make me purchase RDR. Is this you? ;)
  8. zhai1987
    zhai1987 Member
    320Coins
    There is still no feedback. I don't know why. But I didn't see the file for scripthookdotnet.log!
      1.4 MB
      238
  9. knaufinator
    Simulation Engineer
    akron,ohio
    1,874Coins
    AC motor, 6DOF
    that likely means scripthookdotnet is not working correct, as it creates and writes to it each time it is run. you need to focus on that before my mod will work. as it depends of a working scripthookdotnet plugin,
    do you have the .asi file in the gtav directory that came with scripthookdotnet?
    check to make sure also that the normal scripthook is working first, use the use the trainer, if you can get the trainer working then scripthook is working, scripthook also has a log file, scripthook.log,.. does that file get created,.. if not,.. then scripthook is not working either,
    maybe list all the files you have in the gtav dir
  10. zhai1987
    zhai1987 Member
    320Coins
    Brother. Help me take a look, thank you
  11. knaufinator
    Simulation Engineer
    akron,ohio
    1,874Coins
    AC motor, 6DOF
    not sure why you have 2 versions of the scripthookdotnet vs scripthookdotnet2,... this may be part of the issue??? not sure..
    I would have to install gtav again and see if I can get it working,.. I may do that this weekend unless someone else can chime in and help
  12. zhai1987
    zhai1987 Member
    320Coins
  13. zhai1987
    zhai1987 Member
    320Coins
    • Hey, bro, any progress?
  14. knaufinator
    Simulation Engineer
    akron,ohio
    1,874Coins
    AC motor, 6DOF
    ive not installed it yet, no...
    I did get the Red Dead Redemption 2 working, I will clean that up and open source the code this week,. then remove it from my dev laptop,.. making room for GTAV again.
  15. zhai1987
    zhai1987 Member
    320Coins
    Brother, can I just copy your files and use them?
  16. zhai1987
    zhai1987 Member
    320Coins
  17. knaufinator
    Simulation Engineer
    akron,ohio
    1,874Coins
    AC motor, 6DOF
    the last image is the source code to the gtavhook script, you need to compile this in order to use it. there was a compiled version released in the github project though so you should not need to compile it again, unless you want to change the behavior....
    you need to focus first on getting, scripthook working, and then scripthookdotnet, you need to verify that they are running. they both create logs when GTAV is run.
  18. zhai1987
    zhai1987 Member
    320Coins
    Bro, I'm new, for getting, scripthook work, then scripthookdotnet, need to verify that they are running. How to operate, what software to view? thank you
  19. knaufinator
    Simulation Engineer
    akron,ohio
    1,874Coins
    AC motor, 6DOF
    I installed gtav, installed scripthookV, installed scripthookVdotnet, created scripts folder in GTAV directory and added my script, copied over the gameplugin to simtools, and ran the game, still works
    Files added, notice there is a scripthookv.log, and a scripthookvdotnet.log file
    my script included in github repo
    scripthookvdotnet.log indicating it is loading my script, that is placed in the scripts folder
    make sure you patch GTAV from this game manager window, and that it sees the game is running
    tuning center indicating correct values
  20. zhai1987
    zhai1987 Member
    320Coins
    Brother. Share the files of scripthookV and scripthookVdotnet, and I'll try again! try
