my first 2dof motion sim diy..! FINISHED!!!
Discussion in 'DIY Motion Simulator Projects' started by iason, Jun 9, 2023.
  1. iason
    iason Member
    - 13Coins
  2. ChuckyP
    ChuckyP Active Member
    Chicago, IL
    738Coins
    Awesome. Glad you got it. Small steps from here as you work through the setups.
  3. iason
    iason Member
    - 13Coins
    you got it!!!! :)not me!! many thanks man!! i dont know what to say!many many thanks!! yes now small steps with the settings!i will post videos!!
  4. ChuckyP
    Chicago, IL
    738Coins
    I was right where you were just a few months ago, and I love troubleshooting. But there are so many variables with this it’s a nightmare.
    Your rig looks like it snapped right to life. Keep the updates coming.
  5. ChuckyP
    Chicago, IL
    738Coins
    Any updates? Has there been progress?
  6. iason
    iason Member
    - 13Coins
    hello !! i was sick! i make a video now. i test pitch only in asseto corsa. and its great!!
  7. ChuckyP
    Chicago, IL
    738Coins
    Hope you are feeling better. As you are starting to test settings might I suggest using Surge and Sway first because you will really feel the motion connected to the car. Looks like it is working well so far.
  8. iason
    iason Member
    - 13Coins
    Surge and Sway is for accelaration? and brake>? now i use only pitch. and i cant tell you how good the rig react . i can feel the movement of the car in uphill and downhill.i will try to fucos one by one begause in the beggining i put more than 2 forses and i lost it
  9. ChuckyP
    Chicago, IL
    738Coins
    You can set up any DOFs you prefer. But now that it is working properly you can revisit the others and simtools will mix them.
    I prefer mostly
    Sway - The feeling you get when you turn the car left and right. You will lean in the opposite direction as the turn which provides the sense of G forces from the turn.
    Surge - the feeling of acceleration and braking. When you press the accelerator you will lean back and when you brake you will lean forward.
    Heave - Gives you the bumps in the road.
    these are my main forces and I add a little pitch and roll just to feel the terrain a bit. But it is all personal preference.
  10. iason
    iason Member
    - 13Coins
    man you are my motion sim Guru!!!I was thinking thar roll was for the g forses in turning. thanks for this detailed explanation!! :)
  11. ChuckyP
    Chicago, IL
    738Coins
    I’m just a few steps ahead on the same path you are. These guys have been helpful to me so it’s good to be able to pay it forward.
  12. iason
    iason Member
    - 13Coins
    i was thinking of that. to pass the thinks i learn to others . its one of the main reasons to be here!!. i try a little sway now. and i have a smile in my face!! its great!!! no i will go for the surge!!
  13. ChuckyP
    Chicago, IL
    738Coins
    That’s what it’s all about. :grin
