Question Motor angle sensor option?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by The_DutchLion_TTV, Jul 18, 2023.
Tags:
  1. The_DutchLion_TTV
    The_DutchLion_TTV New Member
    27Coins
    Hi all,
    Would a accelorometer like AZDelivery GY-61 compatible with ADXL335 Accelerometer Angle Sensor Module compatible with Arduino work on a 2DOF motion rig powered by wheelchair motor?
    Best regards,
    The Dutch Lion
  2. GWiz
    GWiz Active Member
    Dentist
    Aberdeenshire, Scotland
    1,510Coins
    Yes, I don't see why not as long as you can write the code and integrate it into your system. Is it for motion compensation purposes?
  3. The_DutchLion_TTV
    27Coins
    I was thinking of replacing the hall sensors by one gyro. Not sure if this is feasable.
    Most likely going for the well known, proven hall sensors.
    Still ordered the gyro, so gonna fiddle around with it.
    Thanks for the reply.
