SimTools v3 Public Beta
  1. yobuddy
    51,652Coins
    SimTools v3 has soft start built in, so probably not needed.
  2. yobuddy
    51,652Coins
    Grid Autosport & Grid 2019 posted, let me know how it goes...
  3. yobuddy
    51,652Coins
    Grid 2 and Grid Legends both updated with yaw, roll and pitch rate outputs.
    Also added udp relay option and axis output direction fixes.
    We also added... :thumbs
  4. yobuddy
    51,652Coins
  5. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    Have problem with ETS2, that after calibration, if truck moves at 60kmh above the rig will move right and left to the roll. And must turn down Sway sensitivity a lot.
  6. huangwenkang
    huangwenkang New Member
    47Coins
    I can't find Extral3 in version 0.1 software
    My dynamic simulator needs to set Extral2 in version 6.1, but I can't find this setting in version 3.0. How do you fix it?
  7. yobuddy
    51,652Coins
    @huangwenkang,
    Roll rate, pitch rate and yaw rate are still included, they are just extra 4 thru 6 now.
    its now Extra6
    Use Extra5
    Also know that in V2, the axis assignments per axis are horizontally orientated.
    But in v2 the axes are vertical.
    @deeph46,
    Seems to be working here just fine, may I see your axis assignments?
  8. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    This my settings.
  9. MR Fast
    MR Fast New Member
    32Coins
    3DOF, Arduino
    Just got my rig working the other day, any tips on the how to use the tuning center, and axis setups, especially traction loss and yaw. Been trying to tune TL and yaw without any other axis, but still very jerky and a bit random. Any help would be appreciated. Apologies if this has been covered in here before.
  10. Moppi07
    Moppi07 New Member
    - 4Coins
    2DOF, JRK
    Hello
    since yesterday sim tool crashes when starting any plugin
    I find 2 entries in the event log
    Name der fehlerhaften Anwendung: SimTools.exe, Version: 3.0.0.0, Zeitstempel: 0x643ebf4b
    Name des fehlerhaften Moduls: KERNELBASE.dll, Version: 10.0.19041.2846, Zeitstempel: 0xb9bbdd8b
    Ausnahmecode: 0xe0434352
    Fehleroffset: 0x00138fc2
    ID des fehlerhaften Prozesses: 0x1418
    Startzeit der fehlerhaften Anwendung: 0x01d9c6a5b2ae2041
    Pfad der fehlerhaften Anwendung: C:\Program Files (x86)\SimTools3\SimTools.exe
    Pfad des fehlerhaften Moduls: C:\Windows\System32\KERNELBASE.dll
    Berichtskennung: e302a31d-6cf1-4416-b02c-164cd590f880
    Frameworkversion: v4.0.30319
    Beschreibung: Der Prozess wurde aufgrund einer unbehandelten Ausnahme beendet.
    Ausnahmeinformationen: CSCore.XAudio2.XAudio2Exception
    bei CSCore.XAudio2.XAudio2.CreateMasteringVoicePtr(Int32, Int32, Int32, System.Object, System.Nullable`1<CSCore.XAudio2.EffectChain>, CSCore.XAudio2.AudioStreamCategory)
    bei CSCore.XAudio2.XAudio2.CreateMasteringVoice(Int32, Int32, System.Object)
    bei SimTools.X3DAudio.Note.‭‪‭‮‌‭‬‏‪‮‮‍‫‏‬‮(CSCore.XAudio2.XAudio2, Int32, Int32, System.Object)
    bei SimTools.X3DAudio.Note.StartNote(SoundType, Single, Double, Double, System.String)
    bei SimTools.ActiveNote.Note.StartNote_Loop()
    bei System.Threading.ThreadHelper.ThreadStart_Context(System.Object)
    bei System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
    bei System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
    do you have any suggestions for a solution?
  11. Moppi07
    Moppi07 New Member
    - 4Coins
    2DOF, JRK
    After disabling vibe it works again
  12. John Murphy
    John Murphy Member Gold Contributor
    Tech Exec
    Virginia, USA
    513Coins
    3DOF, DC motor
    When I install the DCS plugin for V3 it overwrites my export.lua file.
    is there a command that I can put into my current export.lua file that would refer to the dcs simtools v3 export? or should i just copy my existing export.lua into the top of the one the plugin creates?
  13. yobuddy
    51,652Coins
    Simply set all your sound cards (vibe settings) to nothing "-", then re-select your cards and your golden.
    I don't know of any command I'm afraid.
    I will look at adding a backup and restore of the original script if found as I think that makes sense.
    I'm not sure what your script looks like, but you could try it.
    (You probably would need to combine the two scripts.)
    @MR Fast,
    You will probably want to use Traction Loss when ever possible.
    PM me, and i can peek at your settings, chat about tuning. etc..
  14. Suglock
    Suglock New Member
    46Coins
    Hello everyone,
    I have 4 Prosimu PRS200 and I can't manage to declare them so that they are supported by the new simtools 3!
    Any ideas?
    Thank you in advance for your help and have a nice day!
    Best regards
  15. John Murphy
    Tech Exec
    Virginia, USA
    513Coins
    3DOF, DC motor
    my original export.lua looks like this...
    local vaicomlfs = require('lfs'); dofile(vaicomlfs.writedir()..[[Scripts\VAICOMPRO\VAICOMPRO.export.lua]])
    dofile(lfs.writedir()..[[Scripts\SimShaker-export-core\ExportCore.lua]])
    local SimShakerlfs=require('lfs'); dofile(SimShakerlfs.writedir()..'Scripts/SimShaker.lua')
    local Tacviewlfs=require('lfs');dofile(Tacviewlfs.writedir()..'Scripts/TacviewGameExport.lua')
    local DCSDTClfs=require('lfs'); dofile(DCSDTClfs.writedir()..'Scripts/DCSDTC.lua')
    pcall(function() local dcsSr=require('lfs');dofile(dcsSr.writedir()..[[Mods\Services\DCS-SRS\Scripts\DCS-SimpleRadioStandalone.lua]]); end,nil);
    Based on that it looks like that you can call other lua scripts from the export. I'll have to do a little reading and see if we can make that happen. It looks like on the surface there are 3 different techniques used in my export.lua, so I'll have to unwind that. Let me know if you get there first:)
  16. yobuddy
    51,652Coins
    I sent them updated interfaces for v3 and I have seen them working.
    So maybe ask them for support, as I know they have the files you need buddy.
    Take care,
  17. John Murphy
    Tech Exec
    Virginia, USA
    513Coins
    3DOF, DC motor
    Are the simtools "slots" in the same order when writing out to the simtools socket (41230) from the DCS export.lua in simtools V2 and V3?
  18. ivan jack
    ivan jack Member
    412Coins
    After Automobilista 2 Update, the motion plugin doesn't work , I tried plugin uninstall/install/Simtools restart procedure but didn't work. I can't read any data from the game when trying to capture Mix/Max Values.
  19. Suglock
    Suglock New Member
    46Coins
    Thank a ot my buddy but I've contacted them and they won't give me the files.
  20. yobuddy
    51,652Coins
    Automobilista 2 now requires Project CARS 2 api to be selected for output:
    https://simtools.us/plugin/?varname=155&color=0e97dd
