Question want to build a small working model of a 6dof simulator
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Shashank Patil, Aug 3, 2023.
Tags:
  1. Shashank Patil
    Shashank Patil New Member
    95Coins
    3DOF, AC motor, Arduino, Motion platform, 6DOF
    Hello everyone, I wish to make a small yet working 6d0f simulator platform for a grade project. I can manage constructing the platform virtually but I'm very clueless so as to what all electronics I'd require for building it apart from actuators. please help out
    154,400Coins
    +11,181 / 57 / -2
    Do you mean you want to build a RC servo powered model of a 6DOF, or something else?
  3. Shashank Patil
    95Coins
    I'm relatively new to this, can you explain it ? I'm doing something like making a scaled down working version of a 6dof stewart platform. But I'm really at a loss with all the electronics and peripherals required to make it.
    154,400Coins
    +11,181 / 57 / -2
    OK, you can 3D print a 6DOF model, with @EricSteijlen's available STL files, then control it with an expansion of @eaorobbie's RC servo code, see the relevant FAQ section: https://www.xsimulator.net/community/faq/build-a-working-model-to-test-your-design-ideas.216/
  5. Shashank Patil
    95Coins
    154,400Coins
    +11,181 / 57 / -2
    No problem, I look forward to following the progress of your project.
    While you are building a model as it is a graded project you may want to dig into some of the 6DOF design theory: https://www.xsimulator.net/community/faq/basics-6-dof-stewart-platform-design.280/
