BRAZILIAN - DIY - 2 DOF
Discussion in 'DIY Motion Simulator Projects' started by Isaac, Aug 17, 2023.
  1. Isaac
    Isaac New Member
    20Coins
    Hello everyone!
    I am from Brazil and this is my 2 DOF motion (DIY).
    first I would like to thank the forum, because it was where I got all the information I needed
    Sorry for the quality of the photos and my bad English. I Don´t speak or write in English, but i am trying.
    I used two computer power supplies, and two 12v motors, and an old office chair served as a seat.
    The project is in the final stage, just missing finishes. I used wood for the top, because of the low price in the area where I live. A Loghtech G29 and a psvr glasses (PS4) will be used
    Please, could i get a simtools diy license ?
    WhatsApp Image 2023-08-17 at 17.02.25 (1).jpeg WhatsApp Image 2023-08-17 at 17.02.25 (2).jpeg WhatsApp Image 2023-08-17 at 17.02.25.jpeg
    153,950Coins
    +11,160 / 57 / -2
    Can you please add some detail like what did you use for a universal joint, what brand are the motors and where did you get them, what control boards and control code is being used, and what PSUs are powering your rig?
  3. Isaac
    Isaac New Member
    20Coins
    Good morning everybody!
    I will try to give more details about the project
    Structure
    The structure was created using 40X20MM metal bars and is 1 meter long by 60 centimeters wide. The painting was carried out with spray paint, using primer and varnish
    Universal joint
    A universal joint from a mercedes benz truck was used. Bought at a used parts store
    Control Boards
    To control the motors I use two H bridges and an arduino.
    Motors
    The motors are from the manufacturer TK8 and were purchased at an industrial goods store in my city.
    It was necessary to make a change in the motor, to include a 10k potentiometer. The potentiometer will serve as a sensor, identifying the position of the motor through resistance variation. The resistance variation caused by the potentiometer is interpreted by the arduino as the position of the upper platform. In the photos we can see the details
    Power supply
    I am currently using two PC power supplies while waiting for a 50A/12v power supply to arrive.
    The two supplies run in parallel so there is no shortage of power to the motors (This could cause the power supplies to shut down during use)
    The arduino code and the wiring diagram used was found right here on the forum. I lost the file with the code and the wiring diagram when my PC's HD burned out. But I will look for the topic of this forum where I found it and include it here.
    This project was carried out about 6 months ago; For a trip I need to pause the construction and I'm resuming it now.
    I hope I have contributed to the community. I will continue to supply this forum according to the progress of the project.
  4. pinochogti
    pinochogti New Member
    7Coins
    I really like your work! I'm looking for information about electronics and its programming. Could you provide me with some information about your project? Thank you very much, my friend! Greetings from Uruguay!
  5. aparecido
    aparecido diy 2dof for flight simulator 2020
    MECHATRONIC TECHNICIAN
    BRAZIL
    - 51Coins
    Good morning, which model of potentiometer did you buy, does it have to be with infinite rotation?
