Question my pc recognizes my sabertooth 2*32 card.
Discussion in 'Motor actuators and drivers' started by titofe, Mar 3, 2023.
  1. titofe
    titofe Member
    640Coins
    2DOF, Arduino, SimforceGT, Motion platform
    hello friends. after a few years of absence for family reasons, here I am to continue my project my 2dof simulator, I bought a new sabertooth 2*32 card but the problem is that my computer does not arrive there. recognize on USB. I have an error. there was someone who could give me a hand it's very nice friends keep it up. thank you
    151,985Coins
    +11,061 / 56 / -2
    Can you please post a picture of the error, so members have some context and basis to offer advice.
  3. titofe
    titofe Member
    640Coins
    hello thank you for your answer ok I will put pictures then for the rest thank you
    151,985Coins
    +11,061 / 56 / -2
    This seems to suggest you have two programs running that are trying to access the same ComPort:
  5. accelero
    accelero Member
    france
    193Coins
    2DOF, AC motor, Arduino
    Hi, which code do you use for your arduino
  6. titofe
    titofe Member
    640Coins
    Hello friends thanks for answer I will answer Noorbeast first I did the programming without any USB plugged in and it gives me this now. I put a photo I also have the green and red light that comes on at the same time. thank you
  7. titofe
    titofe Member
    640Coins
    Hello my friend for your for your answer now I answer, Accelero the code arduino Uno RacingMat 2dof sabertooth Arduino.thank you
    151,985Coins
    +11,061 / 56 / -2
  9. titofe
    titofe Member
    640Coins
    Hello yes yes of course I am a taker of all that you can bring me I recharge the program and I will come to you thank you good luck.
  10. titofe
    titofe Member
    640Coins
    Hello I just downloaded the file you asked me for but I have an error that is displayed immediately like this photos. thank you
    151,985Coins
    +11,061 / 56 / -2
    My guess is that you are not using the correct port in SMC3. You can find the Arduino in Device Manager of Windows, note the correct port number, then configure SMC3 correctly.
    Also make sure the Arduino IDE is correctly configured for the Uno.
  12. titofe
    titofe Member
    640Coins
    Hello thank you for your answer yes I will do the configuration I will put photos to follow the evolution good continuation to you thank you very much.
  13. titofe
    titofe Member
    640Coins
    hello friends following several messages posted I managed to connect my tout savoir card to my computer knowing in fact that it was a usb cable which was not good
  14. titofe
    titofe Member
    640Coins
    Me the problem that now it disconnects every time
  15. titofe
    titofe Member
    640Coins
    m carte saberthoos
  16. noorbeast
    151,985Coins
    +11,061 / 56 / -2
    Under what circumstances do the disconnects happen? As soon as you plug it in, or during violent movement, say like in a crash?
  17. titofe
    titofe Member
    640Coins
    hello every time I shut down the computer and I come back the next day to make the new settings well that's when it shuts down I have to reset. thank you
  18. noorbeast
    151,985Coins
    +11,061 / 56 / -2
    That sounds like it could possibly be a port conflict, are you running SMC3 and SimTools at the same time, or anything else using the same port number?
  19. titofe
    titofe Member
    640Coins
    hello No no I only use one door there is nothing else on it but I will start everything again with a new photo the new connections and I will put everything online and we will take it step by step thank you
