SCN5 ilk damage workaround (for latest gen controllers)
Discussion in 'Motor actuators and drivers' started by egoexpress, Mar 17, 2009.
  1. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    422Coins
    Got some advice for a workaround from Mirai support:
    The latest generation of SCN5 controllers have 3 IO modes which can be selected via the latest Dyadic PCtool software.
    In Air Mode 1 the ILK input has no function (releases the actuator blocking).
    If TBVST is running while connected to a SCN5, we need to check the Setup screen to see if the option to select different PIO modes appears.
    If the option does not appear the controller is too old.
    This feature is not backward compatible.
    Good luck!
    If you need the tool, PM me.
    Regards
    Christian
  2. Skaut69
    Skaut69 Member
    UK, Hull
    335Coins
    My Actuators serial number with damaged ILK:
    1. SN9B004719EG
    2. SN9B004620EG
    I managed to switch them to Air Mode 1 ! - and after that: detect in Force-Profiler.
  3. maurilio
    maurilio New Member Gold Contributor
    - 52Coins
    3DOF, AC motor
    Hi Guys,
    I have the same problem with my scn5 from frex. I got ilk error message on profile startup.
    could someone help me to solve it ?
    Thanks,
    Maurilio.
  4. egoexpress
    422Coins
    You've got a pm with the application.
    Btw, please post your SCN5 serial numbers here, thanks.
    Regards
  5. maurilio
    - 52Coins
    3DOF, AC motor
    Hi egoexpress,
    The serial numbers:
    sn9b004787eg
    sn9b004788eg
    Thanks for quick reply.
  6. FAG
    FAG New Member
    Perm/Russia
    413Coins
  7. egoexpress
    422Coins
    Weird, didnt know that. I cant imagine the purpose :?
    @Maurilio
    Your serial numbers are higher than Skaut69', so the tool should work.
    Regards
  8. Skaut69
    Skaut69 Member
    UK, Hull
    335Coins
    maurilio - did you manage to do it. Did you switch to Mode 1 in TBVST Tool ?
    Tell us if you have some problems with this.
  9. maurilio
    - 52Coins
    3DOF, AC motor
    Hi guys,
    I tried but no sucess. :(
    The TBVST tool don't connect to scn5.
    The program start comuncation and then get an error and quit.
  10. Skaut69
    Skaut69 Member
    UK, Hull
    335Coins
    Are you getting any message with this error or it is just a crash ?
  11. maurilio
    - 52Coins
    3DOF, AC motor
  12. FAG
    FAG New Member
    Perm/Russia
    413Coins
    I already on myself have checked up and all works for me. Though to connect it was terrible.
  13. Skaut69
    Skaut69 Member
    UK, Hull
    335Coins
    Swap to that blue one (i`ve send you link to eBay). Few guys and me use it without problems. You can also check great cable/module from SimXperience.com
  14. maurilio
    - 52Coins
    3DOF, AC motor
    Hi guys,
    Thanks all for the support. The problem was on the rs485 based on chip PL2303 only support full duplex. Changing the rs485 and reprogram the actuators on the air mode1. Works perfectly.
    I have dump the left and right firmware and change to original dyadic.
    The frex system use only one port to comunicate to left and right actuators. Some one use the same way or one port to each actuator?
  15. egoexpress
    422Coins
    Great! :cheers:
    Concerning your other issues. Please open a new thread in the proper forum section, to keep this thread here on topic. Thanks!
    Regards
