SimTools v3 Public Beta
  1. John Murphy
    John Murphy Member Gold Contributor
    Tech Exec
    Virginia, USA
    513Coins
    3DOF, DC motor
    turns out the shortcut I was using to run simtools v3 was creating the problem... dont know how or why, but recreating the shortcut solved the problem.
  2. yobuddy
    51,524Coins
    Update pushed...
    The SimTools v3 Changelog is now available from the SimTools update page in v3.
  3. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    In V3, can I save Min/Max Tuning into file for backup?
  4. yobuddy
    51,524Coins
    Yes, go to the Options page, then click the Export Wizard button at the bottom right of the page.
    Then select a Game Plugin, then select the game plugin you want to backup, then select a Custom Game Plugin. (with at least the Motion option added like in the pic below)
    This will export the game plugin with all of it's profiles intact.
    You can simply drag-drop the backed up plugin into the main gui at any time to re-install.
    Let me know how it goes buddy. :thumbs
    Take care,
  5. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    Does Global Settings also saved in that exported file?
  6. yobuddy
    51,524Coins
    The Global settings get saved into, and then re-installed from, the setup file.
    You can go back into the export section, and export a setup plugin (just click next on the options page to leave everything as default, as they are now).
    Then if you ever want to re-setup SimTools v3, just like you have it working now, you simply:
    1) Install SimTools v3.
    2) Drag-drop your setup file into the main gui.
    3) Drag-drop your custom game plugin into the main gui.
    All done - your ready to play, with no settings to configure at all.
    Let me know if you have any more questions buddy.
    Take care,
  7. Blame73
    Blame73 Well-Known Member
    8,314Coins
    I missed the changelog while updating, is it possible to retrieve it somewhere else?
  8. richdelta9
    8,850Coins
    The log will not show up until the next time you update, because it is not there until after you install this update.
    You can view the changelog at https://simtools.us/simtools-changelog/.
    You can also access this from the link on the SimTools website downloads-links page.
  9. paxton84
    paxton84 New Member Gold Contributor
    2Coins
    hello everyone! iam totaly new to simtools v3 and motion in general. I want to ask if it is possible to install plugins like project cars 1 and 2 ? Repo is Nj motion,because i have a seatmover from them (compact r seatmover).
    Or can i import plugins from anywhere to Simtools version 3?
    Because in the pluginmanager there are just a few games like dirt rally 2.0 or Asetto Corsa Competitzione...
    but no Project Cars which is little bit confusing to me.
    Thank you!
  10. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    Question regarding the Limit travel.
    Which way to proper to max out the travel ?
    - By a Sensitivity.
    - Axis Limitting.
    - Percentage Axis Assignment.
    - Or in SMC3 stuff.
    153,728Coins
    The initial range and hardware configuration should primarily be set in SMC3.
    But the range of travel is just one aspect, it is far more important that the travel is fast and accurate.
  12. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    I will try configuring again later.
    My rig is responsive and accurate to what game do, especially when on bump, kerb, run through gravel, etc (small stuff that I run through) . But I can't fell the pitch and roll much. I can feel heave with only 20% assignment.
  13. Blame73
    8,314Coins
    You can fine tune your settings editing Max/Min Game Limits under Min/Max Tuning tab.
    To manual change values press Capture, edit the values, Save, then Stop
    EDIT: or use the sliders (but I can't stand not rounded numbers like 5,87564389. :D so I manually input them so it would be 6 or 5,5 or 5,75. Yes I know, I have problems...)
    • Funny Funny x 2
  14. ivan jack
    ivan jack Member
    412Coins
    99273 [/QUOTE]
    You are not alone! :)))
  15. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    At last, it seems I managed to get some more details where previously I can't felt it. As I used gearing for potentiometer, I changed the ratio of it and now some details more pronounced. Also, I did another axis calibration after change the ratio.
  16. Norton
    Norton Member
    retired 35 years
    Wildwood, Mo
    180Coins
    I have gotten Iracing to work just fine, I have about nine racing games. I have only downloaded one other and that is Project Cars 3 so far into the V3. But no matter what I try I can't get it to work in the game. My setting do work when I test them but nothing with my chair in the game. Project Cars 3 does work in the older version of simtools?
  17. yobuddy
    51,524Coins
    Did you turn on the shared memory in the game? See here:
    https://simtools.us/plugin/?varname=154&color=0e97dd
  18. Norton
    Norton Member
    retired 35 years
    Wildwood, Mo
    180Coins
    Yes sir that did it. I had NO and 8UPD and Project Cars 2. Changed it to Project Cars 2, and Off and Project Cars 2. Works like a charm.. Thanks for all your help. Love the new look, thanks again.
  19. bob williams
    bob williams OSW sfx100
    IT
    Ermelo, Netherlands
    113Coins
    Hi, is it possible to make the GPL plugin available for Simtools v3?
    Thanks!
  20. Airbas72
    Airbas72 Member
    - 7Coins
    3DOF, Arduino
    Hello, I downloaded and installed SimTools 3, it was very informative, I quickly figured out the settings, but when I connected my 2DOF test platform, the axes shifted from the central position by 40 percent in pitch. I tried to fix it in the settings but nothing worked. Works well in SimTools earlier versions
