New Member - 4 Actuators vs 3DOF Gear motors?
Discussion in 'New users start here - FAQ' started by Pterfloth, Sep 19, 2023.
Linear Actuator on each corner or 3DOF gear driven motors?
  1. Linear actuator
    0 vote(s)
    0.0%
  2. 3DOF gear driven motor
    1 vote(s)
    100.0%
  1. Pterfloth
    Pterfloth New Member
    22Coins
    Hello!
    I am Pat from Vancouver Island in BC, Canada. Preparing to embark on a motion simulator build. I currently have a folding rig from Next Level so I am starting from scratch.
    My first question is should I build an a linear actuator based rig with an actuator on each corner or a 3DOF gear motor drive rig? Which provides the most realistic and useful motion for sim racing? I want to build something that has low latency and compliments my current DD wheel and 4-Dayton transducer setup.
    Your experience and feedback would be very much appreciated! TIA
    152,977Coins
    +11,116 / 56 / -2
    Technically speaking there is the chance with a 4 actuator peg leg design that fast movement may result in an actuator not being in contact with the ground, resulting inn a false motion cue,
    But in practice lots of members have built 4 actuator designs with no real issues reported.
    Actuators are more noisy than rotary powered rigs, but their movement is linear, which is a slight advantage.
    So I think the choice is more one of personal preference and related consideration such as space and cost.
  3. Gadget999
    12,066Coins
    4 peg leg actuators is only 3 dof
    Simpler to use 3 actuators not 4 for a more stable and accurate rig
