the crew motorfest plugin
Discussion in 'News' started by izhangt, Sep 23, 2023.
  1. izhangt
    izhangt Member Gold Contributor
    - 91Coins
    2DOF, Motion platform
    hi, is there an option to use the crew 2 plugin for these one?
    thx
    153,944Coins
    +11,158 / 57 / -2
  3. izhangt
    - 91Coins
    153,944Coins
    +11,158 / 57 / -2
    No idea, you would have to try it and it really depends on what changes the game devs did or did not make under the hood.
  5. izhangt
    - 91Coins
    Works with the crew 2 plugin just patch the documents motorfest carpet and press Doble click in play of simtools v3 crew 2 plugin
  6. Ricardo Queiros Goncalves
    Ricardo Queiros Goncalves New Member
    - 6Coins
    Can You please explain how to Patch Motorfest folder in My Documents, what do you mean by "CARPET"?!?!
    I've already tried everything i know but no Luck.
    Much appreciated.
    Thank you in advance!
    Ricardo
  7. izhangt
    - 91Coins
    Carpet = folder
    To patch is easy
  8. Ricardo Queiros Goncalves
    - 6Coins
    EASY???!!! But how to PATCH?! ;-)
    Thank you for you quick response!
  9. Ricardo Queiros Goncalves
    - 6Coins
    Hello izhangt,
    I am trying to "patch" the Crew Motorfest folder in documents to work with the Crew 2 plugin in Simtools v3 like you explained, but i am doing something wrong or missed something, already checked the UDP ports via CMD and all are triggered, game 3000, 3001, etc... and 4123 for Simtools, but no motion at all, neither telemetry data on Simtools Min/Max Tuning in Input!
    The Patch thing was in Simtools V2, Patching a Game in Simtools V3 and dont know what it is!
    Is select the folder when the plugin is being installed?! or something else...?
    Could you please explain in detail how to patch or the necessary procedures to make it work?
    Much appreciated for your help.
    Thank You
  10. yobuddy
    51,545Coins
    The Crew Motorfest has no telemetry output for simulators that I have seen.
  11. Joyfull Arcade
    Joyfull Arcade New Member Gold Contributor
    - 4Coins
    SimforceGT, Motion platform
    Hi there, hope this is the right place, I have 3 cockpits and they all use simtools V2, so I;m trying to get Motorfest running. Does anyone know how to use the crew 2 plugin with motorfest using simtools V2? Or is there a standalone plugin for motorfest yet?
