RC Model for Motion Simulation
Discussion in 'SimTools compatible interfaces' started by eaorobbie, Jul 17, 2013.
  1. noorbeast
    153,950Coins
    +11,159 / 57 / -2
    Videos are too large for hosting here, so use YouTube and the tool provided here in the post editor to insert a video into a post.
  2. Airbas72
    Airbas72 Member
    - 7Coins
    3DOF, Arduino
    thanks I got it
  3. arthur577
    arthur577 New Member
    - 8Coins
    HI, i am building RC model just like you did as my first steps,
    it seems like i can control the servos from the arduino serial plotter but i am not recieving any data from simtools in output test
    what am i missing?
    153,950Coins
    +11,159 / 57 / -2
    Use @eaorobbie's code: http://www.xsimulator.net/community/marketplace/rc-model-code-for-arduino-uno-2dof-expandable.89/
    Connection diagram http://www.xsimulator.net/community/threads/rc-model-for-motion-simulation.4600/
    arduino code
    Interface setup - IMPORTANT - Assuming a 2DOF for SimTools 2 the Interface Output should be set like this R<Axis1a>~L<Axis2a>~
  5. arthur577
    - 8Coins
    i uploaded the new code , and it works in serial plot as expected
    then i am turning game engine going to output testing and nothing happens :(
    i suspect that there just not comunicating how can i check this? upload_2023-10-6_19-8-52.png
  6. Vlad1225@45
    Vlad1225@45 New Member
    110Coins
    Hello, help with the simulator, I connected everything according to the sketch diagram, loaded it into Simtools, entered everything. The servos don't respond at all; when loading the RC Model Test_InterfaceConfig.cfg file it gives an error сим1.png сим1.png сим2.png сим3.png сим2.png сим3.png
  7. Vlad1225@45
    110Coins
    153,950Coins
    +11,159 / 57 / -2
    As per my previous comment:
    There can't be any spaces and it looks like you are missing ~ on the end.
  9. Vlad1225@45
    110Coins
    hi, I fixed the servos errors when pressing the on button in the test section but still nothing moves when moving the sliders
  10. Vlad1225@45
    110Coins
    also, tell me how to connect 2DOF to the LFS game
    153,950Coins
    +11,159 / 57 / -2
    LFS must be run before being patched for motion: https://www.xsimulator.net/communit...run-in-first-person-mode-before-patching.365/
    Grab a copy of the SimTools manual and keep it handy for reference: https://www.xsimulator.net/community/faq/rtfm-start-with-the-official-simtools-documentation.117/
    Then see the motion profile tuning tips in the FAQs: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    153,950Coins
    +11,159 / 57 / -2
    Is the ComPort correct for your Arduino? You can check in Windows Device Manager.
  13. Vlad1225@45
    110Coins
    yes that's right, I uploaded the sketch
  14. Vlad1225@45
    110Coins
    I checked the comport again, everything is correct, but still nothing works. What am I doing wrong?
    153,950Coins
    +11,159 / 57 / -2
  16. Vlad1225@45
    110Coins
  17. Vlad1225@45
    110Coins
    I turned off the antivirus and reinstalled SimTools, but when I turn on the test, the drives go to the middle position and nothing happens when I drag the sliders
  18. Vlad1225@45
    110Coins
    It doesn’t work at all, please help me, what am I doing wrong?
    153,950Coins
    +11,159 / 57 / -2
    Can you please post pictures of all of your current settings.
  20. Vlad1225@45
    110Coins
