DIY 2 dof Motion Simulator
Discussion in 'DIY Motion Simulator Projects' started by Francesc, Oct 8, 2023.
  1. Francesc
    Francesc New Member
    16Coins
    4DOF
    Hi, I'm Francesc. I wanted to post here what has been the process of building my 2 dof racing sim.
    In this thread I'll be showing all the steps i've followed (and ALL the problems i've had) building my setup.
  2. Francesc
    Francesc New Member
    16Coins
    4DOF
    In this post i'll make a list of all the materials i've used to make the structure and also the electronics.
    STRUCTRURE:
    Several meters of 2x4cm steel tubes.
    - Metric 10 threaded rod.
    - 5mm steel platen.
    - An office chair.
    - 1 metric 20 articulated bearing. (which I later had to replace with a Cardan mechanism)
    - 4 metric 10 articulated bearings.
    - Metric 10 screw caps.
    This are the materials we used, we made the base improvisating a little bit, but it turned out real nice and stable.
    ELECTRONICS:
    Arduino UNO
    - 2 BTS 797O 43A arduino motor controllers.
    - 2 100K potentiometers.
    - 2 12V 46A power supplies.
    - 2 24V 250W electric Motors.
    This was pretty much what I used to make the whole setup.
    To controll the motors I used SMC3 and SMC3 Utils, which worked pretty well. Now I only need to download SimTools and the plugins for Assetto Corsa.
    I'll leave some photographs of the construction process.
  3. Francesc
    Francesc New Member
    16Coins
    4DOF
    1696766122949.jpg 1696766122977.jpg 1696766122922.jpg 1696766122895.jpg 1696766122863.jpg 1696766054909.jpg 1696766054945.jpg 1696766055010.jpg 1696766055037.jpg 1696766055063.jpg 1696766170911.jpg 1696766170937.jpg 1696766307169.jpeg 1696766327554.jpg
  4. Francesc
    Francesc New Member
    16Coins
    4DOF
    Now that I have all of the structure, electronics and part of the software intstalled, I only need to download SimTools and test it with a real game. Wish me luck! (I'll post a video of it when I get it working)
  5. Antonio1986007
    Antonio1986007 New Member
    - 94Coins
    Hello, I really like your 2dof design, in mine only the seat moves and I would like the entire platform to move with the steering wheel, I have engines similar to yours, have you tested them under load? I want to know if they heat up a lot, sorry for my English, I use a translator, greetings from Spain
    153,890Coins
    +11,154 / 57 / -2
  7. Francesc
    Francesc New Member
    16Coins
    4DOF
    Hi Antonio, I'm from Spain too. At the moment I've tried them half the power with me over for about 15-20 minutes, but only with the SMC3 test. That power hasn't been warmed almost (if they were a little warm, but almost nothing). Hi Antonio. I've only tested them at half the power with me on it for about 15-20 minutes, but just with SMC3 testing. At that amount of power, the motors almost didn't heat (only a tiny little bit).
  8. Francesc
    Francesc New Member
    16Coins
    4DOF
  9. Antonio1986007
    - 94Coins
    My motors, when I had been playing for a while, did get hot. I put a PC fan on it and the change was brutal. They didn't get hot at all for hours and hours. By the way, what size are the connecting rods? I don't see them well in the photo. They seem quite long
