DIY 2 DOF on a budget
Discussion in 'DIY Motion Simulator Projects' started by Denis Mowberry, Aug 21, 2023.
  1. Denis Mowberry
    Denis Mowberry Member
    New Zealand
    89Coins
    I am looking at a 24v 350w motor from AliExpress but the output speed is 300rpm .Do you think this is to fast
    153,734Coins
    Do you have a link to the full specs?
  3. Denis Mowberry
    New Zealand
    89Coins
    350W brush motor
    Rated speed: 3000rpm/min
    Gear Ratio: 9.78:1
    Actual speed: 300 rpm
    Torque: 1.1N. M
    Weight: 3 kg
    153,734Coins
    I consider the torque at 1.1N. M is likely way too low for most designs.
    For most designs with a reasonable amount of inherent leverage I would suggest a minimum of 20nm of torque, and for compact designs twice that.
  5. Denis Mowberry
    New Zealand
    89Coins
    Thanks for that. I will try a bit more with the motels I have. I need to reduce the amount the motors move as they are moving 180 degrees. I have tried in smc3 reducing clip limit but nothing changes . How do I adjust the amount the motors move
  6. Denis Mowberry
    New Zealand
    89Coins
    I just seam to have far more questions than answers this motor lists rated torque and stalled torque . Which one should I be looking at
    Product Name
    Worm Gear Motor
    Voltage
    24V
    Rated torque of motor
    6 N.m
    Stall Rated torque
    52 N.M
    153,734Coins
    Continuous rated torque is the motor's continuous torque that it can output at rated speed, close to the max speed of the motor. This is a better judge of the motor's performance as it's the motor's torque at speed.
    Continuous stall torque is the motor's continuous torque at 0 speed (at stall). This is the locked rotor torque. Manufacturers test this by locking the rotor and then monitoring the motor temperature as current is powered into the motor.
    Most manufacturer's if they list a continuous torque and don't tell you if it's at stall or at speed, is typically at stall. The rated torque takes into account the spinning (magnetic) losses and thermal (I2T) losses of the motor. At 0 speed, these losses are 0 and thus the stall torque is higher than the rated torqued.
  8. Denis Mowberry
    New Zealand
    89Coins
    I have made steady improvements with tuning my rig but am unable to reduce the amount of movement the motors have . They move a full 180 deg and as they are a little small and under powered I would like to reduce this so I am only using the area of maximum torque . If I can just get it a bit better I will post my start to finish build . Thanks.
  9. 90kgOver300m
    90kgOver300m Member
    Maintenance technician
    United Kingdom
    263Coins
    I found if the limits are set to 255max, that is the minimum movement for your motor / pot setup. I wouldn't worry about it too much, as when you load simtools and begin to program your axis, you czn control their range of motion on there much easier.
  10. Denis Mowberry
    New Zealand
    89Coins
    Sorry for the dumb questions but can you tell me what adjustments to make in sim tools. Is it just by reducing the % numbers
  11. 90kgOver300m
    90kgOver300m Member
    United Kingdom
    263Coins
    Yeah that's correct, for example I have my traction loss set to about 40%, if it was 100% it crashes into a bracket
  12. Denis Mowberry
    New Zealand
    89Coins
    U Screenshot (8).png sing the tuning center in sim tools the game data input is all showing 0 is this correct
  13. noorbeast
    153,734Coins
    The game has to be running to provide telemetry, was that the case when this image was taken?
  14. Denis Mowberry
    New Zealand
    89Coins
    No the game was not running do I need it to be running 2 screens to see it when the game is running and what should I expect to see
    153,734Coins
    If you check out the Tuning Center while a patched game is running the telemetry will be evident in the top row on the green banner.
  16. Denis Mowberry
    New Zealand
    89Coins
    After doing more research into new motors for my rig I am still unsure as to what will best suite my needs I have found a 24v 250w motor putting out about 10nm at 300rpm . My rig has the motors at the front about 900mm from the pivot point . Would 10nm be enough and is a speed of 300rpm to fast.
    153,734Coins
  18. aparecido
    aparecido diy 2dof for flight simulator 2020
    MECHATRONIC TECHNICIAN
    BRAZIL
    - 51Coins
    I'm saving my coins to buy a weekly package....
  19. Denis Mowberry
    New Zealand
    89Coins
    I decided I could not get my rig to move how I wanted it to using wiper motors so I have bought 2 24volt 250 watt motors with a shaft speed of 120rpm .What length should I make the arms that join the motor to the connecting rods. I want as much movement as I can get without over loading the motors
    153,734Coins
    Have a play with SimCalc plugging in the dimensions of your rig, to get an idea of the tradeoffs between design and physics: https://www.xsimulator.net/communit...e-linear-speed-and-forces-of-your-design.270/
    I would guess 50-60mm CTC is likely in the ballpark, but it is easy to drill additional holes in the levers to experiment beyond that, with real world performance being the best guide.
