Showroom 3DOF motion simulator with linear actuators
Discussion in 'DIY Motion Simulator Projects' started by Martti Rand, Feb 27, 2023.
  1. Martti Rand
    Martti Rand New Member
    Software developer
    Tallinn, Estonia
    98Coins
    3DOF, Motion platform
    My motion simulator project started actually as another project. I dreamed about omni threadmill which I could use for moving around in virtual reality.
    So I wanted to try out simpler version and made sliding platform on which I can do "moon walk" and walking on place. It was tilting sliding platorm as pitch and roll.
    For this I first built linear actuators. I got inspiration from FlyPT - 6DOF Brushless DIY Actuators project and have chosen many parts from that project.
    Actuators are using SFU1605 ball screw rods with 36V 4000RPM 0.44Nm 184W Brushless DC Motors from STEPPERONLINE with simple BLS-510 BLDC motor driver.
    I used ESP32 boards with firmware from FlyPT project to control actuators via USB interface.
    This is the first version of the actuator.
    Turned out that the motor of the actuator was not powerful enough to properly test motion platform. Also motor controller has not enough options for fine tuning actuator movements.
    So I improved actuator build with much more powerful motor and controller. For next ones I used D6374 150KV BLDC motor with max torque of 3.86Nm paired with AMT102-V 8192 CPR encoder. For motor controller I chose ODrive for plenty of control and power output. Also actuator frame is now made from steel.
    Testing out the new actuator video
    Testing out sliding platform with one axis. I used Kinect 2 for tracking body movement and adjusting tilt according to position.
    Back to 3DOF motion simulator build
    As the new actuator working good, I constructed three of them for my simulator.
    Here is CAD drawing of platform.
    Actuators have cnc like mounting plate with mounting holes.
    Platform plate is connected with actuators using male threaded single row joint rod ends. They are fixed with 3D printed adapters to mounting plates. Other half is fixed to platform plate with long M12 bolts. Probably need to enforce those connections with plate.
    and actual build this far. Screwed straight to the floor with hinges at the moment. Used 21mm plywood for plate.
    For powering the rig, there is Mean Well 2.4 kW, 48 VDC, 50 A PSU.
    Next steps
    Integrate the rig with SimTools and test out the platform.
    Install car seat, build FFBoard based direct drive wheel and petals.
  2. Martti Rand
    Software developer
    Tallinn, Estonia
    98Coins
    Despite having difficulties finding time for the project, I finally have a working rig.
    I reinforced the joints with metal parts, installed some safety dampers for actuators in case motors lose power and platform fall down and put motor controllers and PSU into the enclosure.
    Next I installed my old Saab 900 electric seat with functional seat positioning.
    To save time I chose to buy wheels and pedals instead of building ffboard based wheel as I planned earlier. I chose Fanatec CSL DD Ready2Race Bundle. It came with CSL pedals, CSL steering wheel P1 V2 and CSL Direct Drive wheel base with max 8Nm of torque.
    I did a simple wood profile based fixture for wheel and pedals.
    Simtools integration
    As I am using Odrive for actuators control, there is no direct support for Odrive from Simtools and no interface plugins.
    I decided to use a can bus for robust communication and to use the usb-can adapter I had laying around. It is AVR controlled USB<>CAN Bus Interface by Michael Wolf.
    As firmware source code was provided, I modified the firmware to get it to work with Simtools. Simtools axis data is sent via serial interface and converted to can frames. Can frames are sent to actuators in format suitable with the Odrive can interface. Incoming axis data includes all three axis positions and will be relayed to all actuators almost simultaneously. Actuators are selected by can node id.
    I spent a lot of time configuring Odrive to control actuators rapidly enough and with good response. Currently I got actuators working 200mm/s although theoretically it is possible to achieve over 400mm/s with chosen motors and encoders.
    Testing equipment
    I have tested the rig with DIRT Rally 2.0 in SteamVR mode. Currently no motion compensation.
    PC specs: Core i9 13900, 32GB DDR4, Z790 chipset, RTX 4090 graphics.
    For VR, I have Meta Quest 2 and use it via Airlink connected to PC WiFi6 adapter. Airlink reliability is quite poor.
    Test drive video link
    Future improvements
    Replace Saab seat with proper rally seat as current one doesn't offer enough side support and is simply too soft.
    Actuators are quite loud at the moment. I think it's because of no vibration dampening.
    Also the PSU is noisy and should replace ventilators.
    Fine tuning axis parameters in Simtools. They have pretty modest settings at the moment.
    If I have more time then add a 4th actuator for 4DOF.
    151,461Coins
    +11,038 / 56 / -2
    Nice work :thumbs
    Any chance of sharing the modified Odrive firmware you got to work with Simtools, I am sure others would likely appreciate that.
  4. Martti Rand
    Software developer
    Tallinn, Estonia
    98Coins
    I didn't modified ODrive firmware, but USB-CAN adapter firmware which communicates with ODrive va can bus.
    That adapter is open source project with firmware, schematics and gerber files. I modified that firmware.
    Here are files for that.
    If anyone is interested in using that then I gladly help with any questions which may arise.
  5. Airbas72
    Airbas72 Member
    - 7Coins
    3DOF, Arduino
    It seems to me that the connection between the actuator and the platform is not reliable, because the plywood can crack or break, although the idea of the platform is very good.
  6. Martti Rand
    Software developer
    Tallinn, Estonia
    98Coins
    I agree. Currently it is working but at some point I probably replace plywood with aluminum frames.
    Also actuator connections to ground are currently very basic and give a bit play, I am thinking about proper connections with separate ground frame.
  7. Airbas72
    Airbas72 Member
    - 7Coins
    3DOF, Arduino
    I like your project, I’m also developing a similar platform, so I pay attention to the little things, you already have experience and I’m glad that you share it.
  8. Rosebomb
    Rosebomb Member Gold Contributor
    147Coins
    I can't open the file for some reason any other way to get it?
  9. Martti Rand
    Software developer
    Tallinn, Estonia
    98Coins
    • Useful Useful x 2
  10. Rosebomb
    147Coins
    looking at that and the problems i have had finding info i can follow about getting odrives to work bldc linear actuators may just be to much for me to figure out.
  11. Martti Rand
    Software developer
    Tallinn, Estonia
    98Coins
    Here is information about ODrive configuration and example CAN frames to send to ODrive via USB-CAN adapter.
    https://protoshop.ee/motion-platform/ODrive_configuration_and_commands.txt
  12. Rosebomb
    147Coins
    Thank you. I will try this. I like the use of linear rails. I am considering using them for surge but was concerned of strength i think your build has convinced me.
