FlyPT Mover 3.5.3
  1. jack071177
    jack071177 New Member
    28Coins
    Hi Smitty, what do you mean with you have to merge everything to a blank window? I also have the problem, that "Continue" doesn't open my mover file. Thanks!
    Daniel
  2. smitty
    smitty Active Member
    933Coins
    If Open does not work, i found right-click..local file.. Merge was able to load the file. Start from a fresh launch (and hit Continue to dismiss the net errors) or even try local file..New to blank everything out first. One .mover file i had to merge in multiple parts by deselecting some of the modules and then doing it again for the rest.
    I hope this can be resolved soon.
  3. kparkin
    kparkin Member
    United Kingdom
    236Coins
    4DOF
    If you click continue and wait for the blank window to open, then wait for the continue window to open again. Selecting continue again will start flypt
  4. jack071177
    28Coins
    Many thanks! Understood and it works.
  5. jack071177
    28Coins
    Many thanks for the explanation!
  6. DerKlausi
    DerKlausi New Member
    117Coins
    Same here - hitting "continue" two times and getting a cup of coffee during the following 10..60s delay does the trick for me. However, I'll have to reconnect all sources & outputs and update COM ports to get it working.
  7. Rainman@121
    Rainman@121 New Member Gold Contributor
    - 30Coins
    AC motor, 6DOF
    Thanks guys, same issue here.
  8. Chipless
    Chipless Member
    146Coins
    I'm also getting the exact same error as those whom have already posted in here. Hopefully someone finds a fix soon!
  9. smitty
    933Coins
    a little workaround until this is fixed:
    edit your hosts file with the line:
    Code:
    127.0.0.1         flypt.dynip.sapo.pt
    You'll still have to 'Continue' thru some errors but it's much faster.
    Obviously profile sharing won't work.
    Be sure to remove this from your hosts file when the app is updated.
  10. Bastiuscha
    Bastiuscha Active Member
    750Coins
    i just blocked the internet access for the mover app, in the firewall. same thing. :)
  11. Motion4Sim
    Motion4Sim Member
    Europe
    705Coins
    i have also the error, so the profile server seems down. if mover will not be updated in the future we can have new sources via the udp custom hook integrated in last mover version. i can write some code to add source not using udp . via mmf to udp or a dll to udp wrapper. if anyone has wishes please investigate about the source and connect to me. but thats not the best solution.
    I hope he's doing well, it would be nice if the mover project could be continued.
  12. Historiker
    9,208Coins
    Hopefully @pmvcda will chime in and give an update on how he is doing. I very much hope that all is well with him and this project has just been sidelined for now.
    • Optimistic Optimistic x 4
  13. DerKlausi
    117Coins
    Is it just me or did at least the lag before error messages pop up disappear?
  14. Motion4Sim
    Motion4Sim Member
    Europe
    705Coins
    i blocked the mover in firewall for extern requests an no more lag before "click continue"
  15. mikl71
    mikl71 New Member
    Belgium
    402Coins
    Hello all, i have a error 403 forbidden on lauch of ptmover , i dont touch nothing and before all was ok any idea please ..and btw i am on win 11 pro
  16. billo2404
    billo2404 Member
    Roma, Italia
    1,236Coins
    AC motor, 6DOF
    hi guys...I have the error too but just press it twice and it works without any apparent problems.
    But today I noticed something:
    If I start SimHub before 'connecting', flyPt tells me it can't find the card even though it is there in the correct COM.
    Just close Simhub and it connects perfectly.
    If I start SimHub after connecting the simulator, the steering wheel buttons stop working and SimHub does not send telemetry data to the phone.
    Do you think it could be linked to the FlyPt Mover problem?
  17. Marco Annunziata
    895Coins
    Hello everyone, just a curious, there is someone else working on the project of flypt or only @pmvcda are working on that?
  18. pmvcda
    15,448Coins
    I'm working on it :thumbs
    • Like Like x 7
    • Friendly Friendly x 5
  19. kparkin
    kparkin Member
    United Kingdom
    236Coins
    4DOF
    FlyPt was created by Pedro and is the only person with the code. He was working on version 4, but he has not been around for a while now. Hopefully he is well and otherwise occupied.
  20. pmvcda
    15,448Coins
    Not been around, but working on it... just right now:
    • Like Like x 10
