Question Need help with the direction of the forces
Discussion in 'SimTools DIY Version' started by siantic, Oct 4, 2023.
  1. siantic
    siantic Member
    616Coins
    Thanks for the clarification :)
  2. siantic
    siantic Member
    616Coins
    How can I check how many degrees my sim can lean?
  3. yobuddy
    51,540Coins
    It does not need to be perfect, so if your sim can tip about 20deg left and right, that is where i would start.
    Take care!
  4. siantic
    siantic Member
    616Coins
    ok, but there is a metod to calculate how many degrees my sim can tip?
  5. yobuddy
    51,540Coins
    You could probably use a phone app (that shows degrees tipped) or something to get a hard answer.
    But its not to important, its just a good starting place is all.
    Take care...
  6. siantic
    siantic Member
    616Coins
    ok thanks I will follow your advice :)
    The numbers that i see on the Tuning Center are expressed in degrees? +4.122 degree and -4.122 degree?
  7. siantic
    siantic Member
    616Coins
    Hi noorbeast.
  8. yobuddy
    51,540Coins
    Roll Pitch and Yaw are in degrees. The rest are in accelerations usually.
    You can check the games data page here:
    https://simtools.us/plugin_library/?repo_id=1&color=0e97dd
    For example, here you can see the output unit.
