Question Deceleration effect
Discussion in 'DIY Motion Simulator Projects' started by motiondynamics, Oct 28, 2023.
  1. motiondynamics
    motiondynamics Member Gold Contributor
    1,235Coins
    2DOF, 3DOF, DC motor, AC motor, SimAxe, Arduino, Motion platform, 6DOF
    Hi, I want to implement the deceleration effect, that is, the platform will have to move softly or hard in proportion to the speed of the car on the track, so if the car has a speed of 50Kmh, the deceleration will have to have a minimal effect, if instead the car runs at 300Kmh, the deceleration must have a very high effect. Which effect should I use?
    153,944Coins
    +11,158 / 57 / -2
    Surge would be the primary axis.
  3. motiondynamics
    1,235Coins
    Hi Noorbeast, ok.
    I saw that for AssettoCorsa, "EXtra1" corresponds to skidding (skidding when cornering).
    What are the effects of Extra2 and Extra3?
    153,944Coins
    +11,158 / 57 / -2
    It depends on the plugin, for racing the convention is Extra 1 for traction loss.
    The common joint use of Extra 1-3 is some flight Sim plugins, were roll rate is used instead of traditional roll and pitch.
    See here: https://www.xsimulator.net/communit...s-extra1-extra2-and-extra3.12465/#post-162934
