Astur-SIM. Cheap DIY 2DOF
Discussion in 'DIY Motion Simulator Projects' started by Mario_Grao, Nov 3, 2023.
  1. Mario_Grao
    Mario_Grao New Member
    mechanical engineer
    Grado, Asturias, Principado de Asturias, ESP
    79Coins
    Hello everyone:
    My intention is to build a simple and cheap 2DOF simulator.
    This is my first simulator, so the main objective is to learn and improve myself and all with the tightest budget possible.
    That's why I will use the materials I have on hand, second-hand accessories and make as much as possible myself.
    153,770Coins
    +11,150 / 57 / -2
    A budget build is a great place to start!
    You will find plenty of helpful information in the FAQs: http://www.xsimulator.net/community/faq/
    In particular check out the Design section: https://www.xsimulator.net/community/faq/design-considerations-resources.24/category
    Use the Enhanced Google Search on the Recent page to find projects of interest to study: https://www.xsimulator.net/community/find-new/posts?recent=1
    I look forward to following your project build.
  3. Mario_Grao
    mechanical engineer
    79Coins
    OK. Thanks for the links.
    I have been reading for a long time, but the information so resumed is much better
    The first thing will be to design and build the cokpit and since I have a cnc router, which is also another DIY project that I did a few years ago, I will design and build it in plywood and using a design that allows me to facilitate the tongue-and-groove manufacturing of the parts. parts. Therefore I will make my own design taking ideas from the website https://opensimracing.com/ and adapting it as necessary. IMG-20231103-WA0013.jpg IMG-20231103-WA0012.jpg
    Then I will make the cnc files and the cutting simulation. IMG-20231103-WA0011.jpg
  4. Mario_Grao
    mechanical engineer
    79Coins
    The first photos in previous post show the cokpit used as inspiration and this one shows the final design with the requirements that I needed, but maintaining general dimensions of the previous one.
    This design minimizes weight, has dimensions adapted to my cutting machine and a more compact design, because I don't have too much space at home either.
  5. Mario_Grao
    mechanical engineer
    79Coins
    After receiving the two windshield wiper motors from a BMW 330, coming from a car scrapyard,
    the next step is to eliminate the ground connection to prevent them from short-circuiting each other during operation.
    This will fry the H-Bridge modules
    The connection of the brush that is attached to the motor chassis is canceled and the one that generates the fast speed is located IMG-20231103-WA0006.jpg IMG-20231103-WA0007.jpg
  6. Mario_Grao
    mechanical engineer
    79Coins
    After receiving all the electronic components, I mount them on a wooden plate to check the correct operation and verify the connection with the software.
    First, load the code onto the arduino board. First has to be edited indicating mode 2 since I will be using H bridges. Imagen de WhatsApp 2023-11-17 a las 17.53.02_781d8c22.jpg
    Then assemble the whole set, using an old PC source, which will not be the final one, since the voltage it supplies is just 12 v and these motors are able to withstand a little more voltage and with it would provide a little more power.
    Let's remember that in the car they work around 14 v and do not cause problems.
    One of the motors didn't work well because stripping the wire, I almost cut the wires and the weld didn't make good contact, but I discovered it and solved it by soldering it again. Remember, they are very thin wires and you have to be careful. Imagen de WhatsApp 2023-11-17 a las 17.52.49_7edeb8d2.jpg
    I have checked that there is no thermal paste in the h-bridge. So, a bit will be added later Imagen de WhatsApp 2023-11-17 a las 17.53.02_775360ce.jpg
  7. Mario_Grao
    mechanical engineer
    79Coins
    I got a seat from an old citroen C2, (it needs a bit of cleaning LOL, but no problem¡)
    so I redesigned the structure and removed the wooden backrest, which will no longer be necessary.
    I've also lowered the anchor height to compensate for the extra seat height
    With the new design finalized I can now start the cut using 15 mm thick plywood
    Imagen de WhatsApp 2023-11-17 a las 17.52.48_1cdd1936.jpg Imagen de WhatsApp 2023-11-17 a las 17.52.49_830d1063.jpg Imagen de WhatsApp 2023-11-17 a las 17.52.45_41c5d24c.jpg
  8. aparecido
    aparecido diy 2dof for flight simulator 2020
    MECHATRONIC TECHNICIAN
    BRAZIL
    - 51Coins
    Good afternoon, with a 10k potentiometer it is also good, I know that the common potentiometer has a premature lifespan, but does it work the same as a hall sensor?
    153,770Coins
    +11,150 / 57 / -2
    Both can provide position, but a Hall Sensor is not damaged by being over rotated, has a long service life and provides great position resolution, the down side is that a Hall Sensor is more expensive than a 10k pot.
  10. aparecido
    BRAZIL
    - 51Coins
    Good evening, thank you very much for the information.
  11. Mario_Grao
    mechanical engineer
    79Coins
    Imagen de WhatsApp 2023-11-20 a las 09.26.53_b55ab8b0.jpg Imagen de WhatsApp 2023-11-20 a las 09.26.54_769d5fb5.jpg IMG_20231129_210102.jpg IMG_20231129_210109.jpg IMG_20231129_210119.jpg IMG_20231129_210342.jpg IMG_20231129_210401.jpg
  12. Mario_Grao
    mechanical engineer
    79Coins
    Next step is steel base for the whole device.
    I´ll use some recycled steel from an old ping pong table and a cardan Joint from Amazon (18 €)
    Still missing some reinforcements, adjustable feet, small wood shelve and paint.
    Picture showss just the beginning.
  13. Mario_Grao
    mechanical engineer
    79Coins
    Because I can't dedicate as much time to it as I want, progress is slower than expected. I have already finished the basic metal structure of the support and although it is still missing the feet, the supports for the motors and the shelves, Imagen de WhatsApp 2023-12-05 a las 20.08.45_9bd61795.jpg Imagen de WhatsApp 2023-12-05 a las 20.08.44_a757233e.jpg Imagen de WhatsApp 2023-12-05 a las 20.08.45_0b165b91.jpg Imagen de WhatsApp 2023-12-05 a las 20.08.44_a757233e.jpg
  14. Mario_Grao
    mechanical engineer
    79Coins
    I have already been able to assemble the complete set in a preliminary manner. Now it's time to start sanding and painting the structure and final configuration of the electronics before joining it to the final assembly. Imagen de WhatsApp 2023-12-06 a las 21.24.31_62521acd.jpg
    153,770Coins
    +11,150 / 57 / -2
    How well do the wiper motors cope with moving the rig, which I am guessing has a fair amount of mass?
  16. Mario_Grao
    mechanical engineer
    79Coins
    I haven't tried connecting it dodo together yet.
    The wood is very light and I'm not afraid of it. But the seat is quite heavy and it may have been a mistake to incorporate it.
    Anyway I'll play around with the length of the crank and the distance to the center of turn to reduce the necesary torque .
    If it still doesn't work well, I'll replace the seat with a much lighter wooden backrest and i´ll have to move the cardan to balance the whole assy again.
    I'll keep you posted when I get more progress.
    Best regards
  17. Mario_Grao
    mechanical engineer
    79Coins
    HI.¡
    having into acount noorbeast coments new back resthas been designed
    I will cut it jus in case car seat be too heavy for my wiper motors. As I said I will try to hack my atx power supply to give 14 volts or more.
    Some similar models work in such configuration, so i will try it
    BR
  18. Mario_Grao
    mechanical engineer
    79Coins
    Next step a bit of paint.
    "Rosso Corsa"¡¡ of course.
    It starts to look something like a rig¡¡ Imagen de WhatsApp 2023-12-20 a las 17.31.31_1acfa9d9.jpg Imagen de WhatsApp 2023-12-20 a las 17.31.31_45194160.jpg Imagen de WhatsApp 2023-12-20 a las 17.31.32_7fe4dc6b.jpg
  19. Mario_Grao
    mechanical engineer
    79Coins
    Goodo Morning every one.
    In order to be able to assemble the components together I will use wing nuts, instead of hex screws. This will allow you to adjust the ergonomics of the rig on the fly without the help of tools.
    To save cost I will make them myself using leftover wood scraps, cut on the cnc machine and incorporating threaded inserts. Imagen de WhatsApp 2023-12-20 a las 17.31.31_428d8f56.jpg Imagen de WhatsApp 2023-12-20 a las 17.31.31_c3bcbb7c.jpg
  20. Mario_Grao
    mechanical engineer
    79Coins
    Washers glued to nuts and Imagen de WhatsApp 2023-12-21 a las 21.39.55_204bca4a.jpg Imagen de WhatsApp 2023-12-21 a las 21.39.54_e7ab2a44.jpg Imagen de WhatsApp 2023-12-21 a las 21.39.54_c9d03a7e.jpg and nuts already assembled, ready for paint ¡¡
