Question Modify potentiometer tolerance parameter (SMC3 V1.0)
Discussion in 'DIY Motion Simulator Projects' started by motiondynamics, Nov 5, 2023.
  1. motiondynamics
    motiondynamics Member Gold Contributor
    1,235Coins
    2DOF, 3DOF, DC motor, AC motor, SimAxe, Arduino, Motion platform, 6DOF
    I need a very important technical information: I need to modify in the SMC3 V1.0 code, the tolerance parameter when the potentiometer is around the central position.
    Where do I find this parameter?
    Can someone tell me in which line of code I can find this parameter?
    153,944Coins
    +11,158 / 57 / -2
    When you say 'tolerance parameter' what do you mean, Dead Zone or something else?
  3. motiondynamics
    1,235Coins
    Hi noorbeast, yes I mean "Dead Zone".
    I already know that you will tell me to change the value in SMC3Utils, but I have already tried to change the value from 0 to 20, but it doesn't solve my problem (continuous oscillations when the actuator is in the center), so I want to try to solve the problem directly on the code.
    For example, this link talks about this parameter, but it is a different code from mine (I use the SMC3 V1.0 code)
    Tolerance parameter
  4. motiondynamics
    1,235Coins
    no solution?
    Isn't there a line in the code that allows you to change the tolerance?
  5. motiondynamics
    1,235Coins
    Can anyone help me?
    Is there a line of code from which you can modify the tolerance or not?
    I think the line of code exists. Does anyone know what it might be?
    It's important
