2DoF Simulator
Discussion in 'DIY Motion Simulator Projects' started by Richard Eaton, Oct 24, 2023.
  1. Richard Eaton
    Richard Eaton Member
    241Coins
    Hi all,
    Thought I'd start sharing my 2dof motion simulator build.
    It now have all the mechanical and electrical components.
    As you will see from my photo's, the electronics are now all wired up and ready to start testing.
    I designed the case and 3d printed it, used internal modified mounts for the boards.
    Next stage test using simtools and then start the frame....
  2. early_m
    early_m Active Member
    Chelmsford
    893Coins
    Hope your 3d printed u-joint holds out! :popcorn
  3. nnelsonn
    nnelsonn New Member
    307Coins
    3DOF, DC motor
    me too.
    Will it be a seat or a platform?
  4. Richard Eaton
    241Coins
    So I thought I'd update this post with my progression, after sorting out issues with the motor's and going grey through the frustration I tried swapping the wires around and hey presto..... Everything started behaving.
    Time to start the rig build, as you will see from the photos I am pretty much there, just trying now to source a suitable gaming chair that I can destroy (Modify) to fit.... Happy to answer any questions, loving the project though.
  5. Richard Eaton
    241Coins
    They seem pretty strong, I've tested with my weight and movement, time will tell.
  6. Richard Eaton
    241Coins
    A few more updated pictures, seat attached, also got an HF8 Haptic Feedback cushion., now need to attach wheel and position pedals correctly.
