problem with license activation
Discussion in 'New users start here - FAQ' started by Rosario porto, Nov 10, 2023.
  1. Rosario porto
    Rosario porto New Member
    - 74Coins
    I have two problems, the first is my license code which is not recognized and tells me to contact the assistance which i already sent several messages explaining the problem.
    The second problem is the game plugins that don't work, in the past I bought the plugin packages several times now I only need fsms 2020 can you help me?
    Thank you.
    153,938Coins
    +11,158 / 57 / -2
    SimTools is a separate entity: https://www.xsimulator.net/community/faq/simtools-and-xsimulator-partnership-explained.275/
    So you will have to contact the SimTools devs, I am sure @yobuddy can help: https://simtools.us/contact-us/
    SimTools v2 plugin access is via membership or forum activity coins, see the FAQs here: https://www.xsimulator.net/community/faq/coins-and-how-to-download-plugins.2/
    SimTools v3 is in open Beta testing at the moment and introduces and integrated plugin repository for licensed installs, while not all plugins are available yet War Thunder is: https://simtools.us/plugin_library/
    SimTools v2 and v3 can be installed on the same PC and use the same license key.
