Simu 6DOF with aasd15a motors and Thanos
Discussion in 'DIY Motion Simulator Projects' started by GRAP, Nov 4, 2023.
  1. GRAP
    GRAP Member
    Dog handler, Maitre chien
    Montpellier
    214Coins
    Hello
    After a long thinking i start to build my 6DOF simu.
    It ll be a usual frame with 6 aasd15 servo drivers and thanos controller.
    I build this sim in one Fablab, LabSud of Montpellier city ( south of France ).
    At the begining, i started with 3D printers but now i change for alluminium.
    i ll follow Peacmaker ideas ;) for mine excpet i must to dismount/mount esasyly becaus it s in the middle of my dinning room. VerinElectrique v16.jpg
    i start to build this idea
  2. GRAP
    GRAP Member
    Montpellier
    214Coins
    I start in wood
    The place ll look like this
    I start with the frame on the ground
  3. GRAP
    GRAP Member
    Montpellier
    214Coins
    Need to clean and paint but first part is finish. i ll use bolts IMG_7124.JPG IMG_7126.JPG to dismount / fix all.
  4. GRAP
    GRAP Member
    Montpellier
    214Coins
    size of my actuator diam 100mn lenght 550 mm
    It s time to play with the CNC of my fablab
    I ll try in aluminium instead 3D printing IMG_6896.JPG IMG_6903.JPG IMG_6905.JPG IMG_6918.JPG IMG_6920.JPG IMG_6951.JPG
  5. GRAP
    GRAP Member
    Montpellier
    214Coins
    and next work IMG_7056.JPG IMG_7057.JPG IMG_7070.JPG IMG_7073.JPG IMG_7077.JPG IMG_7079.JPG IMG_7093.JPG
    • Like Like x 5
    153,758Coins
  7. GRAP
    GRAP Member
    Montpellier
    214Coins
    Thank s
    With all the tools of my Fablab, i can work better and faster
  8. GRAP
    GRAP Member
    Montpellier
    214Coins
    Actuators are not fully finish because i m waitting one pice so time to take care of power controller.
    One steel fram and one box in wood around. Big box ll cut pefectly with 180w lazer. IMG_7144.JPG IMG_7146.JPG IMG_7148.JPG IMG_7153.JPG IMG_7159.JPG IMG_7169.JPG IMG_7172.JPG IMG_7186.JPG IMG_7195.JPG IMG_7197.JPG IMG_7198.JPG
  9. GRAP
    GRAP Member
    Montpellier
    214Coins
    Ccreation of the cylinder fixing.
    To finish the actuators , the up and down axes are now just missing.
    IMG_7107.JPG IMG_7112.JPG IMG_7115.JPG IMG_7116.JPG IMG_7191.JPG IMG_7192.JPG IMG_7224.JPG IMG_7223.JPG IMG_7221.JPG
  10. GRAP
    GRAP Member
    Montpellier
    214Coins
    Painting time., i start the seat and the electronic for the cockpit IMG_7574.JPG IMG_7590.JPG IMG_7597.JPG IMG_7600.JPG IMG_7601.JPG IMG_7608.JPG IMG_7609.JPG
  11. GRAP
    GRAP Member
    Montpellier
    214Coins
    This week, it was video test with 3 projectors
    IMG_7669.JPG IMG_7671.JPG IMG_7708.JPG IMG_7709.JPG IMG_7718.JPG IMG_7723.JPG IMG_7725.JPG IMG_7727.JPG
  12. Misanthrop
    Misanthrop Active Member
    826Coins
  13. GRAP
    GRAP Member
    Montpellier
    214Coins
    No, it's being tested because I don't know the height. It's just a white sheet hung with pins
  14. Lgars39
    Lgars39 Member
    Jura
    208Coins
    Extremely careful work...congratulations really
  15. Dirty
    All the way up front.
    7,970Coins
    Hey :)
    Will you be using a cylindrical projection in combination with a 6DOF platform? Will those projectors and projection surfaces be mounted on the platform?
    I hope so, 'cos that would be a first! Awesome!
  16. GRAP
    GRAP Member
    Montpellier
    214Coins
    Hi
    It is not really cylindrical but it is a half-cylinder of 2.20 m in diameter with a U on both sides of 90 cm.
    I don't have enough space in my apartment at the moment since the 3 projectors are fixed to the ceiling. I will need a gymnasium or a cathedral....
  17. GRAP
    GRAP Member
    Montpellier
    214Coins
    i test the motion today and it s alive !!!!
    I dont see where to add direct video mp4 so i ll add pictures.
    WhatsApp Image 2024-07-26 à 03.15.06_4df977ef.jpg WhatsApp Image 2024-07-27 à 02.06.19_6a0e1d0a.jpg WhatsApp Image 2024-07-27 à 02.06.19_de5b2b59.jpg WhatsApp Image 2024-07-27 à 02.06.20_8e222c5d.jpg
    Next, i ll test 1 transducteur and 1 double fan for the wind.
  18. noorbeast
    153,758Coins
  19. GRAP
    GRAP Member
    Montpellier
    214Coins
    Fist test with one humman ....
  20. GRAP
    GRAP Member
    Montpellier
    214Coins
    IMG-20240810-WA0001.jpg IMG-20240810-WA0002.jpg IMG-20240810-WA0003.jpg IMG-20240810-WA0005.jpg IMG-20240810-WA0006.jpg IMG-20240810-WA0007.jpg IMG-20240810-WA0009.jpg IMG-20240810-WA0012.jpg IMG-20240810-WA0013.jpg IMG-20240810-WA0015.jpg IMG-20240810-WA0016.jpg IMG-20240810-WA0019.jpg
    Time to build the simpit inside.
