2dof project in progress
Discussion in 'DIY Motion Simulator Projects' started by aparecido, Nov 23, 2023.
  1. aparecido
    aparecido diy 2dof for flight simulator 2020
    MECHATRONIC TECHNICIAN
    BRAZIL
    - 51Coins
  2. aparecido
    BRAZIL
    - 51Coins
  3. aparecido
    BRAZIL
    - 51Coins
  4. aparecido
    BRAZIL
    - 51Coins
  5. aparecido
    BRAZIL
    - 51Coins
    2 H Bridge Driver Module 43a Bts7960 Bts7960b - Arduino
    1 Switched Source 30 Amps Stabilized 720w 24v
    2 hummel wheelchair motors 300watts 24vdc
    1 kit cardan ear with crosshead 4 holes diameter 90mm
    2 10k Linear Potentiometer With L20 Splined Shaft
    3 bars 6 meters metalon 20x40x1.5
  6. aparecido
    BRAZIL
    - 51Coins
    Now it's time to do the tests, then apply primer and paint.
  7. aparecido
    BRAZIL
    - 51Coins
  8. aparecido
    BRAZIL
    - 51Coins
  9. aparecido
    BRAZIL
    - 51Coins
    now it's time to adjust with smc3 and SimTools
  10. aparecido
    BRAZIL
    - 51Coins
  11. aparecido
    BRAZIL
    - 51Coins
  12. aparecido
    BRAZIL
    - 51Coins
  13. aparecido
    BRAZIL
    - 51Coins
    I'm going to install the chair and make a video in flight simulator.
  14. aparecido
    BRAZIL
    - 51Coins
    Could someone help me, configure roll, pitch, surge, heave, sway... (in flight simulator)
    153,848Coins
    +11,152 / 57 / -2
    First grab a copy of the SimTools manual and keep it handy for reference: https://www.xsimulator.net/community/faq/rtfm-start-with-the-official-simtools-documentation.117/
    Also see the flight related comments in the motion profile tuning tips: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    For flight profiles start with roll and pitch, or where supported by the plugin you can use Extra 1 and 2 in place of pitch and roll, as roll and pitch invert from one axis extreme to the other at 180 degree in-game inversion. SimTools also has an Anti-Rollover checkbox function, see the manual.
    Total axis allocation for general aviation flight profiles can be closer to 80-90% of both the available roll and pitch axis, as it is unlikely both will be at their extreme range at the same time. But be a bit more conservative in axis allocation for acrobatic and combat profiles that do use extreme maneuvers.
  16. aparecido
    BRAZIL
    - 51Coins
  17. aparecido
    BRAZIL
    - 51Coins
  18. aparecido
    BRAZIL
    - 51Coins
  19. aparecido
    BRAZIL
    - 51Coins
    I had to change the mechanics of my movement, it improved a lot, photos attached.
  20. aparecido
    BRAZIL
    - 51Coins
