Bug Simtools Not Connected
Discussion in 'SimTools Pro & Entertainment Version' started by kiennt, Aug 13, 2023.
  1. kiennt
    kiennt New Member
    - 70Coins
    4DOF
    Hi every one, I don't understand why my SimTools is currently not functioning and displaying a "Not Connected" error as shown in the image. However, when I try the "output testing," the degrees of freedom (dof) still work properly. They used to work fine in any game I had installed and played before, but now they don't function in any game. Please help me with this issue. upload_2023-8-13_22-15-28.png
    PS: Previously, before installing the AC Mod, I was using my DOF normally. This issue only started from the day before yesterday.
    Thank all
    153,938Coins
    +11,158 / 57 / -2
    If you have installed a mod that in any way messes with game telemetry that may interfere with a plugin, but if the issue affects multiple games it is more likely that something is interfering with communication, often that is antivirus or firewall, so temporarily disable those and test.
  3. yobuddy
    51,543Coins
    Did the IP addresses get changed in either app?
    Under the tools button, the ip address for each app should be 127.0.0.1 when used on the same PC.
  4. kiennt
    kiennt New Member
    - 70Coins
    4DOF
    Thank you, Youbuddy. Indeed, the IP address on my simtools has been changed to 192.168..., and when I set it to 127.0.0.1, everything is working fine. I appreciate your help very much
  5. kiennt
    kiennt New Member
    - 70Coins
    4DOF
    Thank you, I tried following your and Yobuddy's method, and everything is working fine now.
  6. kiennt
    kiennt New Member
    - 70Coins
    4DOF
    I am currently getting the NOT CONNECTED error as shown in the image. I had previously added the WRC10v1, WRC2023, and WRCGenerationv4 plugins, which I downloaded from the simtools website. Thank you!
    Detail:
    System.NullReferenceException: Object reference not set to an instance of an object.
    at SimTools_GameEngine.frm_TuningCenter.LoadGameList()
    at SimTools_GameEngine.frm_GameEngine.frmMain_Load(Object sender, EventArgs e)
    at System.EventHandler.Invoke(Object sender, EventArgs e)
    at System.Windows.Forms.Form.OnLoad(EventArgs e)
    at System.Windows.Forms.Form.OnCreateControl()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.Control.CreateControl()
    at System.Windows.Forms.Control.WmShowWindow(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
    at System.Windows.Forms.ContainerControl.WndProc(Message& m)
    at System.Windows.Forms.Form.WmShowWindow(Message& m)
    at System.Windows.Forms.Form.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.9181.0 built by: NET481REL1LAST_C
    SimTools_GameEngine
    Assembly Version: 0.2.6.0
    Win32 Version: 0.2.6.0
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/SimTools_GameEngine.exe
    ETFgktGMYNvzVOhtEdFZFkYsRAjH
    Assembly Version: 0.0.0.0
    Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.8.9037.0 built by: NET481REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
    Win32 Version: 4.8.9206.0 built by: NET481REL1LAST_B
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
    Win32 Version: 4.8.9037.0 built by: NET481REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Core
    Win32 Version: 4.8.9200.0 built by: NET481REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    Accessibility
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    System.Runtime.Remoting
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    Log
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/Log.DLL
    System.Management
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
    Interface_PluginAPI
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/Interface_PluginAPI.DLL
    AMC_InterfacePlugin
    CodeBase: file:///C:/Users/KienNT/AppData/Local/SimTools/GameEngine/InterfacePlugins/AMC_InterfacePlugin.dll
    HyperAXIS_InterfacePlugin
    CodeBase: file:///C:/Users/KienNT/AppData/Local/SimTools/GameEngine/InterfacePlugins/HyperAXIS_InterfacePlugin.dll
    JRK_InterfacePlugin
    CodeBase: file:///C:/Users/KienNT/AppData/Local/SimTools/GameEngine/InterfacePlugins/JRK_InterfacePlugin.dll
    Jrk
    Assembly Version: 1.1.0.1
    Win32 Version: 1.1.0.1
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/Jrk.DLL
    UsbWrapper
    Assembly Version: 1.5.1.0
    Win32 Version: 1.5.1
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/UsbWrapper.DLL
    MemoryMap_InterfacePlugin
    CodeBase: file:///C:/Users/KienNT/AppData/Local/SimTools/GameEngine/InterfacePlugins/MemoryMap_InterfacePlugin.dll
    Network_InterfacePlugin
    CodeBase: file:///C:/Users/KienNT/AppData/Local/SimTools/GameEngine/InterfacePlugins/Network_InterfacePlugin.dll
    SCN_InterfacePlugin
    CodeBase: file:///C:/Users/KienNT/AppData/Local/SimTools/GameEngine/InterfacePlugins/SCN_InterfacePlugin.dll
    Serial_InterfacePlugin
    Assembly Version: 1.0.0.1
    Win32 Version: 1.0.0.1
    CodeBase: file:///C:/Users/KienNT/AppData/Local/SimTools/GameEngine/InterfacePlugins/Serial_InterfacePlugin.dll
    AxisAssignments_PluginAPI
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/AxisAssignments_PluginAPI.DLL
    Generic2DAdvanced_AxisAssignmentsPlugin
    CodeBase: file:///C:/Users/KienNT/AppData/Local/SimTools/GameEngine/AxisAssignmentsPlugins/Generic2DAdvanced_AxisAssignmentsPlugin.dll
    Generic2DBasic_AxisAssignmentsPlugin
    CodeBase: file:///C:/Users/KienNT/AppData/Local/SimTools/GameEngine/AxisAssignmentsPlugins/Generic2DBasic_AxisAssignmentsPlugin.dll
    Generic2DStandard_AxisAssignmentsPlugin
    CodeBase: file:///C:/Users/KienNT/AppData/Local/SimTools/GameEngine/AxisAssignmentsPlugins/Generic2DStandard_AxisAssignmentsPlugin.dll
    Default_InterfacePlugin
    CodeBase: file:///C:/Users/KienNT/AppData/Local/SimTools/GameEngine/InterfacePlugins/Default_InterfacePlugin.dll
    Microsoft.GeneratedCode
    Default_AxisAssignmentsPlugin
    CodeBase: file:///C:/Users/KienNT/AppData/Local/SimTools/GameEngine/AxisAssignmentsPlugins/Default_AxisAssignmentsPlugin.dll
    Game_PluginAPI
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/Game_PluginAPI.DLL
    WRCGenerations_GamePlugin
    Assembly Version: 3.0.0.0
    Win32 Version: 3.0.0.0
    CodeBase: file:///C:/Users/KienNT/AppData/Local/SimTools/GamePlugins/198_GamePlugin.dll
    enabled.
    For example:
    <configuration>
    </configuration>
    153,938Coins
    +11,158 / 57 / -2
    What version of SimTools are you using v2 or v3 Beta?
  8. kiennt
    kiennt New Member
    - 70Coins
    4DOF
    I’m using v2
    153,938Coins
    +11,158 / 57 / -2
    You can't use v3 Beta plugins off the simtools website with SimTools v2, they are incompatible.
  10. kiennt
    kiennt New Member
    - 70Coins
    4DOF
    Oh, I understand. Does SimTools v3 currently support all games as v2 does, so that I can upgrade to v3?
    153,938Coins
    +11,158 / 57 / -2
    Not yet, but you can install v2 and v3 on the same PC and use the same license for them.
  12. Andre Durand
    Andre Durand New Member
    45Coins
    I hope I'm in the right place. I recently purchased a rather new 6OF motion sim which leverage SimTools. I have v3 beta right now. I recently got everything working but Simtools loses connection with the rig at what appears to be somewhat random times after starting just fine. I need to reboot my PC in order to get it to re-connect to the rig and then when I start iRacing, within 5-25 seconds it disconnects and a reboot is required. I have checked the USB connections several times, and the cable is the cable that came with the rig. Any suggestions would be greatly appreciated.
  13. Andre Durand
    45Coins
    Ok I may have found the issue. I uninstalled Norton and just made it through an entire iRacing race without a hitch. Wow is motion awesome.
