Question Arduino Uno 8bit or 10bit?
Discussion in 'SimTools compatible interfaces' started by nnelsonn, Nov 9, 2023.
  1. nnelsonn
    nnelsonn New Member
    307Coins
    3DOF, DC motor
    Hi
    in the specs from the Arduino Uno, i have seen that the Uno's has two 8bit timer and one 16bit timer. Various threads and the docu shows in the interface setting in simtools a rsolution from 10 bit.
    But it is possible to choose 8bit. What are pros and cons between 8bit and 10bit? Can the Uno work with 10bit?
  2. yobuddy
    51,657Coins
    I think what they are talking about is the ADC of the Uno?
    If you use 8 bit's the pot's can detect 256 stop points on your axis, where in 10 bits it can detect 1024 stop points for your axis.
    Hope that helps.
  3. nnelsonn
    nnelsonn New Member
    307Coins
    3DOF, DC motor
    I understand. Thank you for your helpful answer
