Active Pedals
Discussion in 'News' started by SeatTime, Oct 28, 2022.
  1. SeatTime
  2. SeatTime
  3. Terje Helle
    Terje Helle New Member Gold Contributor
    138Coins
    Oh, I want 3 please… But it’s a LOT of money.
    Maybe some smart xsimulator heads can make a DIY receipt for this.
  4. SeatTime
    I could easily build a set, the issue would be the software to drive them properly. IMO only maybe worth it for the brake, even then I think a simple transducer does a pretty good job for feeling ABS etc. Personally would save my budget for other G systems (harness etc), which I think would give a better bang for buck.
  5. Gadget999
    12,029Coins
    Is it basically a pedal that is on a linear actuator ?
    If you have a motion sim this is a waste of time
    All you need is a vibration motor that is activated when the abs is operating
  6. stahl2005
    stahl2005 New Member
    34Coins
    Alil to pricey for me looking to build a set. I 3d printed a bunch of parts and got the vibration to work with a arduino nano. Im hoping motors feel ok.
  7. wingert
    wingert Active Member
    678Coins
    4DOF
    the sense of active pedal is not only vibration, it the possibility to create rapidly every kind of brake behavior soft or hard or even a clutch with the software.
  8. Tags..(VR)
    Tags..(VR) Member
    indiana
    - 6Coins
    Oh I Want This !!
  9. Tags..(VR)
    Tags..(VR) Member
    indiana
    - 6Coins
    To bad i have a miss match of a DIY build and learn after that it wouldn't fit on my motion rig.
  10. Shige Tanaka
    Shige Tanaka FREX Actuator Supplier http://www.frex.com/gp/ SimAxe Beta Tester Gold Contributor
    FREX
    Osaka Japan
    - 274Coins
    2DOF, 6DOF
    I will try to make an active brake pedal if the software is available. It will be a hydraulic system with a slave cylinder at the end of the fluid line, where an SCN high-ratio pitch short-stroke actuator is attached. ;)
  11. Misanthrop
    Misanthrop Active Member
    646Coins
    So the same thing that Asetek will be offering in the future.
