New rig - need help with SimTools
Discussion in 'DIY Motion Simulator Projects' started by Danila-686, Nov 27, 2023.
  1. yobuddy
    50,992Coins
    I can't see what your doing on screen in the video, but everything looks right except parking location.
    May I see your parking location settings.
  2. Danila-686
    Danila-686 Member
    157Coins
    3DOF, Arduino
  3. yobuddy
    50,992Coins
    Please make sure you don't run SimTools and FlyPt at the same time.
    Set this page like this and click Save and Park.
  4. Danila-686
    Danila-686 Member
    157Coins
    3DOF, Arduino
    thanks . I'll try it tomorrow. tell me, do you need to change anything in these settings?
  5. yobuddy
    50,992Coins
    Nope, your good to go!
  6. Danila-686
    Danila-686 Member
    157Coins
    3DOF, Arduino
    I did everything as you said. nothing has changed at all. I didn't run the FlyPt program. there are no changes in the game. Everything is the same as in the video. https://youtube.com/shorts/u63KkRsKIzs
    Later I will try to launch the Dirt Rally 2.0 game through simtools. Please tell me. there are also some subtleties for installing the plugin.
  7. Danila-686
    Danila-686 Member
    157Coins
    3DOF, Arduino
    maybe I should try another interface plugin? I have serial installed, maybe I should install HyperAXIS?
  8. Danila-686
    Danila-686 Member
    157Coins
    3DOF, Arduino
    Please help me from the very beginning. I thought that the WRC 23 game was not working for me. and there is. But I decided to check and downloaded plugin rally dirt 2.0, installed the plugin in the right folder. but the situation is exactly the same. I ask you to help me from the very beginning. I am ready to remove all programs and step by step perform the necessary actions from the very beginning. I don't understand where I'm missing something.
  9. yobuddy
    50,992Coins
    There is nothing to install by hand?
    You use the plugin manager and they install with the click of a button.
    If you installing plugins by hand. this could be some of the problem I think.
    There is no way the hyper-axis or the scn driver will work with your setup, you need scn equipment to use that driver. It is defiantly a serial based Arduino sketch.
    As far as I can tell from you video, everything is working except the shutdown as the front goes to the floor?
  10. Danila-686
    Danila-686 Member
    157Coins
    3DOF, Arduino
    all right. the platform is running and receiving telemetry data. But it doesn't work correctly. I'll upload the video to YouTube later. how the platform works with flypt in dirt rally and on YouTube there is a video of the srt80 working with wrc ea sports. I downloaded the rally dirt 2 plugin for simtools and it does not work correctly as with wrc. accordingly, something is wrong in the settings.
    is it possible to contact you through anydesk? You should have seen everything for yourself. I really don't understand how I can solve this problem.
  11. yobuddy
    50,992Coins
    In v3 you just click install, you don't need to download anything is all.
    What does this mean buddy?
    As you can't just unzip the plugin and drop them in a folder is all.
  12. Danila-686
    Danila-686 Member
    157Coins
    3DOF, Arduino
    C:\Users\Boroda-686\Documents\My Games\WRC
  13. noorbeast
    151,991Coins
    +11,061 / 56 / -2
    What it means is that v3 introduces an integrated plugin repository system and installer, to avoid the very types of issues created by users doing unexpected things.
    So you access and install plugins from inside v3 itself.
  14. Danila-686
    Danila-686 Member
    157Coins
    3DOF, Arduino
    For some reason, drivers with a bitrate of 921600 do not work for me. They only work on 115200
    Perhaps this is the reason?
    my operating system is Windows 10
    Fly pt and simtools operate from 115200 to participate in the dirt rally
    it doesn't work with a different bitrate
  15. Lebois
    Math teacher
    2,565Coins
    Hey sorry I don't come here often...it's easier to come ask for some help on my discord...
  16. Danila-686
    Danila-686 Member
    157Coins
    3DOF, Arduino
    Help please. I've already tried everything. my platform works well with flypt, but I can't set it up properly. I bought it specifically for the WRC 23 game. But even with dirt rally, it doesn't work correctly. He twitches as he wants. My platform is srt 80. I haven't tried anything for 2 months. It 's terrible . I've already changed the control unit. now 921600 is working. but almost nothing has changed. Please give the exact correct settings for the WRC ea sports game. at least some of them. then I'll finish it. or I'll figure out what the reason is. in the settings or in my srt80.
